Thread: Check valves
    May 2017
    Default Check valves
    Where do you need these? I was under the impression you need them on vent lines but saw you don't in a post. In the process of upgrading my 06 LSV G1.
    New to boating and surfing
    Aug 2011
    Commerce Lake, MI
    You can put them on the vent lines of bags only, not tanks. Make sure they are mounted so that they can allow air/water out to the drains on the side of the boat, and not the other way around, otherwise the bags won't ever fill.
    2017 Moomba Craz
    May 2017
    Ah, didn't realize it was a tank set up on the other boat, makes sense. Backwards valve would not help for sure! Thanks for the reply.
    Oct 2010
    Lake Wylie NC Area
    Check valves can be a benefit in some parts of the system and are necessary in other parts of some systems. Depends on system design, pump type used and height of the sac.
