Results 1 to 6 of 6
Thread: depth gauge
08-23-2017, 04:52 PM #1Member
- Aug 2016
- 98
depth gauge
08 lsv, found my air mar transducer, in my bilge. its plugged in. I purchased this boat used from a not so great dealer, where would my depth gauge be if I had it? I have an open gauge spot on the rt side of dash. do I just buy a gauge or is there more parts. thanks for the help
08-23-2017, 08:17 PM #2Member
- Mar 2017
- 76
I have an 07 LSV and my depth finder stopped working this year. Had to replace it, cost about $400. Sorry to hear about your luck.
2007 LSV
08-24-2017, 12:31 PM #3
I have the stock depth gauge from my 2008 XLV. if it would work for you, shoot me an offer... simple with a black face.
www.TraysonsToybox.com
08-24-2017, 02:46 PM #4
I have the same issue on mine, although I still have the gauge in the dash. It reads "- - -" all the time and the puck in the V-drive locker is just floating around. I have tried holding it under an inch of water like all other transducer instructions say prior to epoxying it down and it still will not work. I plan to replace the transducer and gauge with a nicer gauge - stock one is very hard to read in daylight. My opinion, a critical gauge like that needs to be readable at a glance! That said, mine has not worked for 1.5 seasons and I don't seem to sweat changing it out much...
2008 OBV
325 EFI with closed cooling
Gravity III with 750's in the rear, 400 stock floor, 750 IBS
Servo valve ballast upgrade
Wetsounds Rev10
JL Amps, WS420BT
2000 Outback LS <-- Sold!!!
310 Carb Direct Drive
800# Rear Locker
750# IBS (should have kept this for the OBV)
Dual Batteries with 2 Bank Charger System
Kenwood Head with Remotes
Too many hours restoring exterior from prior negligence to count!
08-25-2017, 06:31 AM #5Member
- Aug 2016
- 98
it appears I have transducer but no gauge in the dash. trayson I want to do a little more research and find out what I NEED. I will keep you in mind give me a week or 2. also does your lcd perfect pass still read out ok? mine is spotty
08-25-2017, 11:51 AM #62008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
