Results 11 to 20 of 39
Thread: Ballast problem
  1. #11
    Aug 2017
    Best pics I could get.
    2019 Supra SL450
  2. #12
    Jul 2010
    Vicksburg, MI
    Vent line coming thru floor should go directly to leg of the bow sac with NO check valve. Vent line for bow sac should be at the nose of the sac and go directly outside of the boat thru the hull with NO check valve.
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
  3. #13
    Jul 2010
    Vicksburg, MI
    With this setup, the bag will drain almost completely by the time the tank is empty.
    Joe
    2014 LSV
    1993 Echelon
  4. #14
    Jul 2010
    Vicksburg, MI
    With this setup, the bag will almost fully drain by the time the tank is empty.
    Joe
    2014 LSV
    1993 Echelon
  5. #15
    Aug 2011
    Commerce Lake, MI
    Agreed
    2017 Moomba Craz
  6. #16
    Aug 2017
    So it seems the hard tank is probably pretty much empty, but the bow bag isn't draining into it properly?
    2019 Supra SL450
  7. #17
    Aug 2017
    Quote Originally Posted by jstenger View Post
    To be clear, you mean the drain line through the floor (to hard tank) with no T to the vent and no check valve, and the fill line should have a T to the hose from the hard tank and to the vent, with no check valve?
    I have 2 check valves and 3 Ts involved with the bow bag.
    2019 Supra SL450
  8. #18
    Aug 2011
    Commerce Lake, MI
    All you need is one hose going in from the hard tank at one of the legs (or both legs) and then a vent line from the tip, to the outside of the boat. No check valves for anything.
    2017 Moomba Craz
  9. #19
    Aug 2017
    OK I'll have to re-plumb it. So it fills and drains from the bottom fitting on one leg? The top fitting is only for venting?
    2019 Supra SL450
  10. #20
    May 2014
    Palm Desert, CA
    Quote Originally Posted by Shoebox View Post
    Correct
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
