Results 1 to 6 of 6
    Default Draining rear bags
    Okay I have upgraded rear bags and they are just not emptying all the way I have to turn the pumps on and lift the bag up to get all the water out. Any help would be much appreciated. I have the bags fill timer set pretty high and I look to make sure they fill all the way up and I shut them off.
    2014 moomba mojo 2.5
    Nov 2016
    Knoxville, TN
    I always try to empty while running on plane or the bow up some, this pushes all the water to the back. If you are draining while static, they will have some left in the them. You could also empty as much as possible, then turn your pumps back on once you are on the trailer at the ramp or an incline. You say you set the timers pretty high? Most recommend 1 minute per 100 pounds, so if you went to #1100, I would try 11:30 fill and drain times....don't forget that there are timers for both. Hope that helps.
    2011 Sea-Doo Wake 155
    Quote Originally Posted by KnoxMojo View Post
    Thanks that helps I'll try that next time. I will have to tell my step dad to start draining while I'm pulling the boat out at the ramp.
    Also adding check valves to the vent lines on the rear bags helps to suck them all the way down by preventing air from entering the bag causing it to lose prime
    May 2014
    Palm Desert, CA
    I have the same problem & I have check valves. It's a pain in the ass lifting up the bags to get the water out 🤦🏼*♂️
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Sep 2010
    Lake wallenpaupack PA
    Make sure the check valves are working. Mine will completely drain with check valves to the extent its looks like they are vacuum sealed bags
    I bought the cheaper check valves from wakemakers. One of them wasn't working properly and wouldn't seal. It ended up the screws where to tight and were contorting the plastic and would close fully. They should shut 100% or your not gonna get the suction
