Results 1 to 9 of 9
    Mar 2013
    Wisconsin
    Default Bags are slow to fill
    It seems that our bags are taking longer to fill than when it was new. Is there a strainer on the bag lines? 2016 Mondo surf edition
    2016 Mondo Surf Edition
    Aug 2011
    Commerce Lake, MI
    I don't believe there is a strainer as they are three separate intakes. Check your impellers to see if they are missing blades or just warn out.
    2017 Moomba Craz
    Mar 2013
    Wisconsin
    Where are they located on a mondo?
    Apr 2013
    Knoxville TN
    If you open the engine hatch, do you see black hoses against transom going to the back lockers?
    2018 Supra SL400
    Aug 2011
    Commerce Lake, MI
    Should have two pumps on one side behind rear panel and one on the other side or all three together. Three screws to remove; one up top and two at the bottom
    2017 Moomba Craz
    May 2014
    Palm Desert, CA
    Quote Originally Posted by klemmy View Post
    It's probably the impellers. My center wouldn't fill up, bought a few new ones & found my center impeller was missing all but 1 finger.
    2 behind port locker (center/port) & 1 behind starboard locker (starboard)
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Mar 2013
    Wisconsin
    Do you think that would be possible with a new boat, 40 hrs on it ?
    Aug 2011
    Commerce Lake, MI
    Sure, if they were run too long dry, you may have burned the impeller.
    2017 Moomba Craz
    Jan 2010
    North Texas
    No doubt. It could happen in the first hour.
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
