Page 38 of 42 FirstFirst ... 283637383940 ... LastLast
Results 371 to 380 of 416
  1. #371
    Commerce Lake, MI
    Quote Originally Posted by GeorgiaDoc2 View Post
    Steeper up front.
    Lower your speed or reduce the surfplate deployment amount, I.e. less of it deployed.
    2017 Moomba Craz
  2. #372
    It also depends on on your riding style and preference, steep can be harder to surf depending on your skill and what your trying to do. A really steep wave is generally really hard for beginners, they tend to go up the wave loose footing and face plant. I ride skim so I prefer a nice gradual, mellow wave. Provides more flats area for skim tricks.
    Take a pic each time from the same angle and then see how it rides after a while you'll know what you like.
    2006 Moomba Mobius LSV - Sold
  3. #373
    Jun 2018
    Thanks Stazi. That worked just perfectly. Decreased the surf plates by 15 each side and it did just what we wanted. Had a great wave, best yet.
    Mark
    2018 Moomba Mojo Pro
    2015 Moomba Mobius LSV - sold
  4. #374
    Commerce Lake, MI
    Mark
    Awesome!!
    2017 Moomba Craz
  5. #375
    Jun 2018
    Quote Originally Posted by goose View Post
    The draft sensor only reads accurately when the boat is sitting still. As the boat moves, water actually drains out of the sensor due to venturi effect. The system stops reading at 4mph, but if you idle with a lot of weight, it can see the reduced level because it will idle less than 4mph. I would imagine your sensor showed full when sitting still and less when moving. Let me know if that isnt the case...
    Matt,
    I watched the AMP bar all weekend. Yesterday boat was weighted with the 3000 factory ballast and an additional 2250 in lead, ballast bags and people. The AMP bar both potential and actual were at the top, both static and moving at 11MPH. Today the boat was weighted exactly the same and the AMP bar was about at the bottom third both potential and actual both static and at speed 10MPH. I took pictures of the screen at each time that I could send if needed. Do I have a problem with my sensor?
    Mark
  6. #376
    Apr 2002
    Matt,
    Mark
    Sorry about delay. Been busy trying to get boats built. haha
    Sounds like Stazi helped you on wake shape. I think it is in an earlier post, but once you get a lot of displacement, you can definitely fine tune shape by playing with Flow plate position. As you have seen, a little less flow % and the wave gets steeper close to the boat. A little more flow % and the wave gets mellow close to the boat. If you watch, it also affects roll and pitch. So, as you really fine tune it, you need to make sure you get them all how you like it. Factory settings will work for most people, but as some of the other guys mentioned, exactly how steep you like it is very personal.
    As to the Amp bar, you can definitely email me pictures, but I think it is still a moving issue. I may not have explained it well enough, but the AMP bar stops reading at 4 mph AND will continue to display that level until you slow back down to less than 4mph. So, if the amp bar is at the top sitting still, then you start idling forward, the amp bar will slowly lower. Then once you get past 4 mph, it will display that until you slow down again. Keep in mind this is actually a complex system and there are filters and data always working in the background, so if you take off one time and get past 4 mph very quickly, then it might not see the reduced amp level. But if next time you take off a little slower, then it catches the lowered amplitude and displays it. Hope that makes sense. Again, the idea behind the amp display is to give you an idea BEFORE you take off of how much displacement you have that day. If you are getting different readings during the day as the boat moves, that is normal and you don't have an issue. If you are getting different results as the boat is sitting completely still with the same ballast and displacement, then yes there might be an issue. Let me know which of these it is.
    Hope that helps!
    Matt Brown
    Product Development Manager
  7. #377
    Aug 2018
    Cedar Rapids
    Thank you very much for the information!
    Long searched for it.
  8. #378
    Sep 2018
    Orlando
    Watching the Supras and Moombas come down the exact same service lines really helps illustrate the difference between Moomba and other “budget” boats.
  9. #379
    Aug 2018
    This might be off a little because this thread has been about '17 and' 18 autowake, but now that the '19s are officially out, what has improved? The website has a lot of marketing, and almost no explanation of what really is better. The price went up almost $500 for the autowake option from' 18 to '19 so does anyone know what autowake with multisensor technology is adding as compared to the' 18s?
    Sent from my SM-G950U using Tapatalk
    2016 Mojo surf edition
    1100lbs rear w/ 475 piggyback mid/ 500lbs IBS/ 600 lbs lead
    ACME 2315
  10. #380
    Aug 2017
    Quote Originally Posted by schwan View Post
    Draft sensor, amplitude, bag-full sensors with auto shut-off of pumps when filling, and I think “predictive state” which I am not in the know on.
    These are at least some changes I am aware of—not a complete list I am sure .
