Results 431 to 440 of 499
Thread: AutoWake questions
05-28-2019, 06:59 PM #431
Sounds good!
05-29-2019, 08:51 AM #432Senior Member
- Mar 2017
- Middle TN
- 232
Figured id try this question here. Is autowake something that can be added/installed later in the new boats? I assume it's a plug in program thing?
05-29-2019, 11:01 AM #433
It would be pretty tough.. it's not just a program. It's a variety of sensors and an inclinomotor as well.
2011 Sea-Doo Wake 155
05-29-2019, 02:01 PM #434Senior Member
- Aug 2011
- 2,522
2006 Moomba Mobius LSV - Sold
05-29-2019, 03:07 PM #435Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
Only to 2017's and up; due to the helm control screen software.
2016 Mojo Surf
Raptor 400
FAE
06-10-2019, 11:30 AM #436
AutoWake questions
Hoping someone can help with this one, I'm trying to recalibrate the roll in the Autowake Settings menu on my 2019. Doing this because Autowake keeps filling port ballast double over starboard. This happens no matter who is in the boat or where weight is. We'll have the wave perfect with manual ballast, turn on autowake and it'll drain starboard to almost zero.
Anyway, when trying to recalibrate roll, I select "yes" when the "set roll to zero" confirmation screen pops up. But then in the main display roll continues to display what it is currently (0.8 as pictured).
Doing this at 20mph with wake perfect, as told to in the 2019 display manual.
Here's what Autowake does at 30% amplitude, with me standing in the center of the boat and no other people/gear on the boat, completely washed starboard side but port looked good:
Here's the Autowake settings screen AFTER setting roll to zero:
2019 Craz
06-13-2019, 04:10 PM #437Junior Member
- Sep 2017
- North Carolina
- 20
I can't comment on the newer screen setup as I have a 2017. But the re-calibration made a huge difference to my ability to use (and enjoy) autowake on my boat. It shipped from the factor with a 1.1 offset, but it always felt way off when surfing (the boat was clearly rolled, but it kept reporting 0 roll and dumping all the ballast on the driver side to try to get to -3. So I used the inclinometer on my iPhone, dropped the boat into the water on a calm day with just me in the middle of the boat. And while the iPhone was reading 0 degrees, the boat was reading 2.8 degrees. So I went in and hit recalibrate and it adjusted the total offset to 2.9.
The wife and I went out after and had the best surf in a long while using Autowake.
Now to figure out the right speed... to get good push, we are down at 9.8, but sitting 5-6' off the back of the boat. And I'm running 1100's in the rear (upgraded from the stock 650s in the original Surf Edition).
heath2017 Moomba Craz Surf Edition
High altitude prop
1140 lb WakeMakers Universal Fit rear ballast upgrade
Autowake 2.0 firmware upgrade (20171121 version)
2013 SeaDoo GTI135SE with ski mode
1984 SeaRay 210 CC - traded
06-13-2019, 04:27 PM #438Senior Member
- Aug 2011
- 2,522
9.8 is my speed too, the actual numbers don't matter, just remember what works for your boat and riding style. No 2 boats will have the same setup or numbers exactly.
06-17-2019, 06:14 PM #439Junior Member
- Jun 2019
- 1
I bought a 2018 MOJO Pro. The sacks in the rear of the boat do not fill the rear. I am not getting the full potential of the wave I want. What brand do you recommend for the 2018 MOJO PRO
06-19-2019, 08:16 PM #440
