Results 1 to 10 of 11
    Jul 2009
    Syracuse Utah
    Default Surf platform wobble
    Hey everybody
    I have a 2013 Moomba LSV. The platform wobbles quite a bit while sitting in the water. It seems loose and makes noise. It appears that there are some screw holes in brackets that attach the platform to the boat.
    Can anyone tell me what is supposed to go here or maybe they have a picture of their own?
    2013 Moomba LSV
    Oct 2010
    Red Deer Alberta Canada
    Mine did the same thing. I think it is from years of bouncing in the water. My brackets don't have the screw slots like yours, so I put plastic shims in the back of the brackets and it is rock solid now.
    2016 Craz
    2007 LSV - Sold
    2003 Outback - Sold
    Jul 2009
    Syracuse Utah
    Quote Originally Posted by Kidder522 View Post
    That is a great idea!
    Actually I think I will do both the set-screws and the plastic shims and see how that goes.
    2013 Moomba LSV
    Those screw holes are for bolts to add tension to the platform to keep it from rattling.
    They work but my experience was the bolts get bent, broken, in the end the bracket keeps getting worse.
    The real solution is upgrade to the 14 year model stainless brackets.
    They aren't the same bolt pattern on your hull but they are easily adaptable by the dealer.
    I was the first to upgrade and several have followed suit.
    The best upgrade ever to your swim deck. No more rattles it's locked in.
    And it's actually easier to remove the deck now. Pull a pin lift off.
    [COLOR="#696969"]
    Jul 2009
    Syracuse Utah
    Do you have any pictures? I'd like to see it if you have any
    2013 Moomba LSV
    I can get some but idk when right now they got me traveling so much
    You can look at any 14 up MOOMBA and it will have the same new brackets they are stainless steel
    [COLOR="#696969"]
    Feb 2012
    South Jordan, Utah
    I found this on Great Lakes skippers website.
    Kurt
    2019 Supra SL 550
    2016 Mojo - Sold
    2006 Mobius LSV -Sold
    May 2014
    Palm Desert, CA
    Quote Originally Posted by moombacraze View Post
    I wonder if those will fit my 15'. Mine doesn't have the hooks for the straps. I thought that was a great idea on the 16s & up.
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Jun 2017
    Pendleton, Indiana
    Composite shims wedged in from the top then cut/break them off... tap in with a hammer.... also those holes should have set screws that tighten down.... I bought new stainless steel Allen head screws.... I believe they were 1/4 20thread screws .... make sure you get stainless and long enough to reach all the way through bracket and into base. Using both the shims and the set screws made a world of difference on mine!!! Solid as a rock now!
    2012 Mobius LSV (Sold)
    2020 Mojo
    Another idea is to drop a stainless lock washer through the space in the top side of each bracket. They will rattle into place but you can get them out with a needle nose plyers when you want to remove the platform.
