Results 1 to 9 of 9
    Feb 2017
    New Braunfels, TX
    Default 325 assault misfire, rough idle especially when hot
    So, a week ago the boat started bogging down under load and key on the fuel pump (high pressure) sounded off so i got replacement and it ran fine for two outings.
    Fast forward to today, first set not issues and i get in the water for second set but then the boat starts running rough and misfiring and eventually died (had to be pulled off by buddy). I bought the boat in February and it ran like crap so replaced every normal maintenance item (plugs, wires, fuel/ oil filter, cap,etc) so don't think that's the first place to look.
    Funny thing is it seems more pronounced when the engine gets hot (gauge reads normal) but after sitting for 45 minutes as we got towed in it started up and sounded fine.
    Any thoughts???
    2009 Moomba LSV
    Aug 2011
    Commerce Lake, MI
    Sounds like the fuel pump is going out
    2017 Moomba Craz
    Feb 2017
    New Braunfels, TX
    Low pressure fuel pump? Just replaced high pressure one.
    2009 Moomba LSV
    May 2013
    Compression test it.
    Jan 2006
    Jacksonville, FL
    Coil pack. My 2003 did it and we replaced a lot of parts. Still did it.
    May 2017
    Amarillo, TX
    Sounds like it needs a compression test...
    Jul 2017
    Central VA
    Are the fuel pump connections all solid? On my 02 Outback they were very lose when I bought it used and fuel supply was intermittently disrupted sometimes, especially if it were choppy out.
    Feb 2017
    New Braunfels, TX
    Update. Low pressure fuel pump was shot making it act like vapor lock. Had an awesome evening out today! Even got a rare slalom run.
    2009 Moomba LSV
    Aug 2011
    Commerce Lake, MI
    Glad you got it sorted out.
    2017 Moomba Craz
