    Default 17 moomba craz dtc ego 3 open / lazy fault
    Keeep getting problems with dtc 134 ego 3 open / lazy fault code. Brand new 17 moomba craz. Only at 1 hour when this happened sounds like an oxygen sensor fault. anyone else have this issue?
    Aug 2011
    Commerce Lake, MI
    Yes. It's not a big deal. Next time you turn off the boat. Switch off the power at the perko switch to reset the ECU. It's just a bug in the software.
    2017 Moomba Craz
    Quote Originally Posted by Stazi View Post
    Okay did that but it still continues to pop up every so often
    Aug 2011
    Commerce Lake, MI
    Mine has done it twice and it's just saying that the O2 sensors took too long to get to full temperature.i wouldn't worry about it unless it's doing it every other time. Like yours mine through the code right around 8-9hrs, and the. Once again around 40 or so.
    2017 Moomba Craz
    Apr 2017
    Hayden Id
    Mine has done it the same amount and at same hours as stazi , it goes away pretty quick though and the code didn't stayed stored when took it in for break in service.
    2017 Craz surf auto wake
    1140 # rears wet sounds
