Results 1 to 10 of 15
    Default Autoflow vs Autflow 2.0
    I have a 2015 mojo surf edition with autoflow. Was wondering if it is worth it to upgrade to the 2.0 plates for the cost? thoughts?
    Mar 2015
    What's the cost?
    2015 Mojo Surf Edition
    1100 rear lockers
    400+ under each rear seat
    700 stock center
    950 ibs
    autoflow 2.0 surf tab upgrade
    FAE
    May 2014
    Palm Desert, CA
    Quote Originally Posted by wetfly112 View Post
    I highly recommend! Easiest upgrade you can do to your wave. Not sure on cost anymore but contact.....
    http://www.wakelandmfg.com/oem
    tturley@wakelandmfg.com
    865-724-1625
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Oct 2016
    The Autoflow 2.0 upgrade kit is $397 plus Shipping. I am trying to figure out what exactly comes with it and the complexity of the upgrade.
    2018 Supra SL 450
    2015 Mojo - Sold
    Where is that upgrade price from? Wakeland or your dealer?
    May 2014
    Palm Desert, CA
    Quote Originally Posted by jbauer View Post
    Should just be new blades, easy swap out. 5-10 min max.
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    Jun 2015
    North TX
    Quote Originally Posted by BrettLee3232 View Post
    Brett, 2 questions if you don't mind:
    1-You kept your old actuators?
    2-What improvement did you see as result of adding the 2.0 plates?
    I'm surfing just fine behind the 1.0 tabs, but this seems like a slam dunk if it improves the wave.
    2015 Mojo
    May 2014
    Palm Desert, CA
    Quote Originally Posted by jeamk03 View Post
    1) No, I did not replace actuators or mounting brackets. Only the blades them selves. I think there's like 6-8 nuts/bolts on each side.
    2) I'm fat so I was having problems going ropeless on light days with just 2 on board. I was constantly pumping to stay in the pocket. New blades installed and only had a driver and I was ropeless. Boat had a lot push. I couldn't really tell if it was bigger or not though.
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    Aug 2015
    Franklin, TN
    I upgraded before the beginning of the 2016 season. It was worth it for sure. We were able to get more push out of the wake. I just replaced the surf plates. Actuators and brackets remained the same.
    2015 Mojo
    Autoflow 2.0
    4700 lbs ballast
    Jun 2015
    North TX
    Sweet! I'm going to order today. Thanks for the input.
    Sent from my SM-G950U using Tapatalk
    2015 Mojo
