Results 1 to 10 of 21
07-10-2017, 09:51 PM #1Junior Member
- Jul 2017
- 8
2016 Moomba Mondo Surf Edition NEED HELP!
Hey guys I have been reading through a lot of forums and can not find a solution to my problem and I have tried almost everything.
My problem is that I can not get my goofy surf side to be clean and surf able. I have played around with filling and draining different spots in the boat also played with the auto flow settings, speed, wake plate and I even purchase a surfgate to attach to the boat.
I am getting really frustrated I have had 7 people in the boat in different spots to see if it cleans up the white wash I am getting it helps alttile but it is not as nice as the regular surf side that I cant ride. Please any pointer to help would be great
07-10-2017, 10:05 PM #2
I'm having similar problems and the consensus is 1100 lb bags in the back lockers. I just ordered them and will try it out this weekend. Mine is a 2015 with man flow but we'll see what the extra weight does.
07-11-2017, 11:51 AM #3Member
- May 2015
- North Carolina
- 94
I have a 14. Goofy side tends to need a lot more listing than the regular side. I also run about 1 mph faster. I have 900 lb rear bags and the manual flow. So I can't help with the auto flow settings.
James
2014 Mondo
93 Four Winns 180 Freedom Sold
07-11-2017, 12:32 PM #4Junior Member
- Jul 2017
- 8
What ballast bags are you putting in. I am most likely going to upgrade to 1100's but I don't know what kind to get or if I need some special fittings? Any advice on this?
07-11-2017, 12:32 PM #5
Agree with JD14Mondo - speed up and lean it more (65%-75% port side & 75% front ballast). Wake plate will help adjust some of the wash too (bring it to 3/4 rather than full up)
2015 Mondo - surf edition w/autoflow
07-11-2017, 01:09 PM #6
How full can you fill your 900's? I see they are 50x22x22 in size which puts a fair amount of the bag under the back seat. Do they conform to the space and mostly fill into the lockers without pushing up on your back seat cushions? I ordered the 1100's which are 50x24x24, so yours are fairly close in size for me to get an idea of what to expect.
07-11-2017, 01:17 PM #7Junior Member
- Jul 2017
- 8
07-11-2017, 01:25 PM #8
I bought Fatsac 1100's. I just bought the 1" fitting that goes into the bags. The quick connect piece will stay on the fill/drain and vent lines when you disconnect. The other side of the fittings that are in the stock bags are glued in so I left them in and ordered new ones, they are cheap.
07-11-2017, 01:35 PM #9Junior Member
- Jul 2017
- 8
Is this the bag?
https://www.wakemakers.com/fly-high-jumbo-surf-sac.html
and is this the fitting?
https://www.wakemakers.com/fly-high-...ting-w743.html
Do you have any issues with the 1100 lbs bags being full?
07-11-2017, 01:44 PM #10
Yes, yes, and not sure yet. I just ordered them and won't be able to test until this weekend. I'm hoping they will work, ton's of guys recommended going to the 1100's so I guess they should work. About 1' of the bag will be under the back seat so I'm hoping the bag will compress in that area and fill up more in the back lockers. You will also need these apparently.
https://www.wakemakers.com/engine-di...nel-saver.html
I'm up in Canada so I'm going to try and build a set this week. Luckily I found the bags and fittings locally so I didn't have to wait for them from the states.
