Thread: Engine code
07-09-2017, 06:23 PM #1
Engine code
moomba spn 707 fmi 3 oc4. What is this?
Sent from my iPhone using Tapatalk2016 MOJO
07-10-2017, 07:21 PM #2
https://www.bakesonline.com/images/M...manualv1.2.pdf
Check this list2020 Supra SL 400
2015 Moomba Mojo(Sold)
2018 Yamaha Waverunner(Just to fool around)
2018 F150 Lariat
sport edition, 3.5lt ecoboost
07-11-2017, 12:12 PM #3Senior Member
- Aug 2006
- Millington TN
- 204
SPN 707 FMI 3 is a low oil level indication. Check your oil with the dipstick. If the oil level is OK, there is an oil level switch on the side of the oil pan. It is on the same side of the engine that the starter is on. Check and make sure the wiring harness plug is plugged into the switch and that the contacts are clean.
Larry Engelbert
Indmar Marine Engines
"Power to the Sport"
07-11-2017, 12:51 PM #4
Thank you... that's exaclty what it was. Connector was fully secure.
2016 MOJO
