Results 11 to 15 of 15
Thread: engine running poorly
06-15-2003, 12:00 AM #11Member
- Jun 2003
- 37
Closed or open
Ar operating temp, should the sensor be closed or open circuit?
06-15-2003, 12:22 AM #12Brian Raymond Guest
cts.
It is always open(kinda,it runs off the ground circuit), but can exceed its parameters. The sensor(if bad) will always default the motor to run rich.Brian Raymond
06-17-2003, 10:49 AM #13
Temp and RPM
Thanks Brian. I got my idle set right in that range and my temp is right in there too.
Richard
2001 Mobius
06-17-2003, 09:06 PM #14Member
- Jun 2003
- 37
How to check the temp sensor.
So, at operating temp, can one short the temp sensor lead to ground or unplug it and see if that helps, or is there a resistance value that idicates proper working?
06-17-2003, 10:40 PM #15Brian Raymond Guest
Temp. sensor on EFI only
Bring the motor to operating temp(160-175deg.) on the analog gauge. Shut the motor off, and disconnect the 2 wire sensor, take a ohm reading by touching the 2 test leads to the terminals inside the sensor. As temperature increases, ohms decrease, and vice versa. there is a temp. configuration for ohms to temp., write down your findings, and contact your dealer to see if it is reading correctly. The font on the temp. gauge is to your advantage, if the gauge reads 175deg., a proper ohm reading will put you around 157deg. This is incorporated to read higher, sooner, so if an overheat happens, you will hopefully shut the motor down b4 it is toast. Brian Raymond
Engine running rich
By dodes in forum Service & RepairReplies: 3Last Post: 08-26-2005, 11:03 AM -
'01 Mobius running bad
By wforic in forum Service & RepairReplies: 1Last Post: 06-05-2005, 10:47 AM -
Running Rough
By cham783 in forum Service & RepairReplies: 2Last Post: 08-15-2003, 05:08 AM -
Running Hot
By wdf in forum Service & RepairReplies: 1Last Post: 06-26-2003, 10:08 PM -
Carbureated Engine Not Running Right
By ChipB in forum Boat OwnersReplies: 9Last Post: 03-01-2003, 10:59 AM
