Results 1 to 10 of 11
    Default New Owner Questions
    I have a 2016 Helix.
    Any idea on where to get a spare transom plug? Mine has a "O" ring on it and I can't find a similar one online. I like the idea of having a spare but don't know if it's really necessary.
    When I trailer my boat without a cover my rear locker lids open and lift up. I tried attaching 2.5 lbs weights to the lift arm with a zip tie but they still spring open. Anyone else have this?
    I didn't get a owner's manual with my boat (dealer demo boat) and I can't find it online anywhere. Moomba's site only shows the 2017 Helix?
    Thanks for any help or advice.
    How fast are you going? I have 17 but never had it over 60
    Quote Originally Posted by moomba156 View Post
    Anything over 50 and they come up.
    I wonder if they changed the shock on the door
    Get some double sided velcro tape and stick one half to the door and the other to the frame. Should hold em down when you close. Also makes that cool "riiiiiiiiiiiiiip" sound when you open. Folks been using it for loose cushions for years.
    Mar 2015
    Try blocking the bilge air inlet vents.
    2015 Mojo Surf Edition
    1100 rear lockers
    400+ under each rear seat
    700 stock center
    950 ibs
    autoflow 2.0 surf tab upgrade
    FAE
    Feb 2013
    Knoxville TN
    Quote Originally Posted by Willyourun View Post
    If you exhausted the sites like skidim, bakes, inboard online, great lakes skip, waterskis, etc, the dealer can get one from SC.
    Feb 2013
    Knoxville TN
    Did you try the main Moomba site?
    Safety & Resources > Downloads
    PDF file
    i don't believe there is such a thing as a 2016 Helix. It was a mid-year release and therefore a 2017 model, even though it was sold in 2016. You can call SC and provide your hull ID number to confirm.
    All my paperwork from the dealer said it was a 2016. I called SC and they said because it was a mid year release it didn't make the 2016 manual. I never thought to ask him look up the hull ID but I might do that.
    Thanks for the other suggestions on the lockers springing up.
