Results 1 to 6 of 6
Thread: Sub not working
    Jul 2016
    Default Sub not working
    Hey everyone so my sub won't turn on now. I am assuming/hoping its a blown fuse. I located two fuse panel boxes to the left of under the helm that control horn, blower, ballasts, stereo, bilge, nav/dock lights. I know there is a 3rd one located somewhere because there is not one for my dash, and the cig lighter ports. I am assuming the sub is on a separate fuse than the stereo seeing the stereo works fine and that has to be on the other fuse panel box. Any idea where that fuse panel box is located. Thanks
    2013, wasnt moomba using the Kicker DX600.5 amp maybe for in-boats and woofer? At least a 5 chnl of some sort, right? If so, there is no fuse just for the woofer. Even then, the woofer amp will have a larger maxi fuse close to where the amp power wire terminates to the main switch or a BUB bar. Wont be a small automotive like fuse.
    My head unit would lose power during battery change over, etc. Whenever it did I'd have to go back in and turn the subwoofer back "on". My old Aiwa receiver in the house did the same thing. Not sure why default is "off" but may be something to check in your head unit settings.
    Jul 2019
    Wink happy fixing it
    My subwoofer did not work today. I hoped you find the information helpful while having fun on an audio website. Finally, I found due to its a blown fuse. Changed the fuse, and works well now.
    Mar 2003
    Springfield Missouri
    What boat do you have? A blown fuse should be quick to find and replacing a fuse doesn't fix the original issue. It just delays it until the fuse blows again.
    SOLD
    Jul 2019
    Thank you, you are right, I shall find what causes it.
