Results 11 to 20 of 20
Thread: Ballast bag cleaning???
06-28-2017, 11:13 AM #11
yes, if you have reversible pumps then they fill and drain from the hole in the hull. The vent line that goes out the side of the boat is where you put the check valve. You can just cut the hose and put the valve in. I put mine about a foot from where the hose goes out the side. You can call Wakemakers and they will walk you through it and make sure you have everything you need. Pretty easy job and I've had great results.
Scott
2021 Craz
1997 Sea Ray 190
06-28-2017, 11:41 AM #12
06-28-2017, 12:35 PM #13
Couple more questions. I see 4 vent holes on my boat, 3 SB and one port. Does this mean the hard tank and IBS have separate vents? Can I add a check valve to the IBS without harming the hard tank? What size are the vent lines?
06-28-2017, 01:29 PM #14
one of those is probably your bilge. Most likely you only have 3 for the ballasts but not sure. If you have a hard tank you will need to check with wakemakers and see if you can still use a check valve. It seams like I read somewhere that you only use check valves with bags and not hard tanks. I could be wrong on that.
Scott
2021 Craz
1997 Sea Ray 190
06-28-2017, 02:56 PM #15
06-28-2017, 06:50 PM #16
'08 Mobius LSV- SOLD!
2017 Mojo Pro
06-28-2017, 08:00 PM #17Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
06-28-2017, 08:04 PM #18
06-28-2017, 10:13 PM #19
06-28-2017, 10:15 PM #20
Yes. I did mine close to the thru hull side to hide it but you can put it anywhere in line from the bag vent and line
For hard tank and ibs connected to it, someone came up with an air break with a tee and a one way spring valve off the hard tank to let air in after the ibs drained
I forgot who , since I don't have a hard tank I am not sure if the whole procedureLast edited by jmvotto; 06-28-2017 at 10:20 PM.
