Results 1 to 10 of 15
    May 2011
    Fargo North Dakota
    Default Sub mounitng help
    I have ordered a 12" sub and box, shallow mount and would like input where to mount it.......my thought is under the passenger dash on an 05 Moomba Outback with my amp and batteries but open to suggestion. Second, the box is carpet, Ive read to remove it and waterproof the box......ho[ping can come up with another option such as getting it up and away from any floor moisture Any help or suggestions would be appreciated!!
    2005 Moomba Outback
    mount it on top of the hump if you can
    Aug 2011
    Commerce Lake, MI
    Mount it in front of the driver. In the passenger compartment is the worst. It will basically muffle the bass.
    2017 Moomba Craz
    Oct 2010
    Lake Wylie NC Area
    open to suggestion.
    Ok, here goes! cancel the order. Go with a traditional, non shallow woofer and build a custom enclosure thats suited for the marine environment and that fits under the helm.
    Jan 2010
    North Texas
    MLA speaks truth!
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
    Yes, Chief MLA speakum the truth.
    May 2011
    Fargo North Dakota
    Appreciate the input and im sure you guys are right BUT im looking for quick easy and simple.
    2005 Moomba Outback
    Oct 2010
    Lake Wylie NC Area
    Quote Originally Posted by langmotorsports View Post
    https://wetsounds.com/pages/products/stealth-AS-10
    quick............check
    easy.............check
    simple..........check
    500W marine 10 just needs B+, ground, remote and RCA. Even beats Meatloaf's 2 outta 3
    Jun 2010
    Benton, LA
    Since we are on the topic of sub mounting....I still have the original factory sub in my XLV mounted into the kickboard. It really doesn't sound good. What is the best way to go to replace it? Should I look at a free air sub and use the same hole (it certainly isn't sealed) or maybe cut that part out? I guess I could mount one of those wetsounds AS-10s above it. How would you experts go about placing a new sub in there? Keep in mind I'm not an audiophile or enthusiast, I just want decent to good, not lake shaking. See pics.
    Edit: I'm over 6 feet tall and I like my leg room. I want to lose as little of it as possible.
    2007 XLV Gravity Games Edition
    340HP CAT/ETX
    ACME 1235 / Fresh Air Exhaust
    1180 Front, 1100s Rear, 400 under Surf Side Seat, Homemade Suckgate, Custom Surf Platform
    Slingshot Hooke, Doomswell Neo, Phase 5 Hammerhead, Parker Surfcraft Phantom
    Oct 2010
    Lake Wylie NC Area
    Tell me about that EQ you got there! What woofer is that, what amp is driving it. How its tuned and how the in-boats are tunes, can effect how even the best woofer, sounds as a complete package.
    With the new Wet Sounds Revo-12FA, this is a honest solution to consider.
