Results 11 to 20 of 20
06-23-2017, 11:00 PM #11
My top ones pop out too. Gotta glue them all in.
Sent from my SM-G930V using Tapatalk2015 Mobius LSV Surf Edition
6.2L Raptor power
1100's and Flow
Acme 1847
2003 Wakesetter xTi - sold
06-23-2017, 11:08 PM #12
06-24-2017, 12:52 AM #13Senior Member
- Jul 2016
- 116
The pic looks like just a plug in bottom. You will put the fly high quick connect fitting there that the connection on end of fill/drain hose connects to. The overflow on top is on the back end also and you put the air release on top, front hole.
Sent from my iPhone using Tapatalk2016 Moomba Craz
2014 Chaparral H2O 21 Sport
1997 Sea Ray 175 Sport
06-24-2017, 12:55 AM #14Senior Member
- Jul 2016
- 116
I used PVC cement. Worked great for me.
06-24-2017, 01:42 AM #15
6.2L Raptor power
1100's and Flow
Acme 1847
06-24-2017, 02:38 PM #16Member
- Apr 2017
- 58
06-25-2017, 11:16 PM #17
Use teflon tape on the threads Easypeasy
06-26-2017, 08:57 AM #18Senior Member
- May 2017
- 171
06-27-2017, 04:34 PM #19Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
You shouldn't need hose extensions on a 2016 Mojo....at least I didn't. Get the quick connect fittings from WM. The bags will come with enough plugs for the other holes. I didn't glue as folks have mentioned, no issues so far but I might rethink that in the off season. Are most folks running something other than a plug for the front top fitting location? Since the back top is the overflow line I didn't think there was a need for a check valve vent fitting (for "burping").
2016 Mojo Surf
Raptor 400
FAE
07-06-2017, 07:13 PM #20Junior Member
- Jun 2017
- Lake Belton, TX
- 3
How did the 24x24x50 sac fit in the sac slot? I'm in the same boat as you are and upgrading my sacs as well. I saw the ones you ordered. I'm a bit concerned with the length since the sac compartment is only around 45-46" long? Are your sacs having to run under the header of the sac compartment pushing up to the bow and pinched? do they fill all the way?
