Results 1 to 7 of 7
Thread: Temp Sensor
    Jul 2015
    Manchester
    Default Temp Sensor
    The temperature gauge stopped working at weekend, the boat runs fine but can be a pain to start when hot I believe the temperature sensor is faulty but I have found 2 at the rear of the engine can someone tell me what each one does.
    The first is to the left (if you have your back to the drivers seat) of the thermostat housing connected to a T which is used to feed the heater.
    The second is on the lower ring of the thermostat housing
    I'm also struggling to find the PCV Value if someone could point me in the right direct that would be great
    its a 2000 Mobius V with a 330HP MPI engine
    Thanks Rory
    First picture looks to be the temp sensor for your ECM
    Second looks like a temp sending unit for your gauge but I'm not positive
    [COLOR="#696969"]
    May 2013
    Fairfax, VA :(
    Isn't the PCV on top of the valve cover? A right angle piece of black plastic in a rubber grommet attached to a hose. Just pull it out if that is what you are looking for.
    2007 XLV Gravity Games
    1,100 in each rear locker
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
    Jul 2015
    Manchester
    Thanks just ordered them from Skidim
    Apr 2005
    Madison, WI
    When my temp gauge stopped working, I changed my sensor and the gauge itself. Neither fixed it. It was the thermostat. It was stuck open and didnt allow the engine to get to operating temperature. Its a cheap fix. Even if it isnt the thermostat, Id change it out anyway.
    Jim Hagen
    Madison, Wisconsin
    facebook.com/signedgewraps
    2011 Moomba Mobius LSV - Exiled
    2002 Moomba Mobius LSV - Sold
    May 2011
    Charlotte, NC
    I was speaking with Discount Inboard Marine about my sensor and they mentioned that a quick test to determine if the sensor was bad was to turn the key so you have power to the dash then remove the lead to the sensor and ground it. If the gauge goes all the way across then the sensor/sending unit is faulty.
    Quote Originally Posted by Rorymulderrig View Post
    Thanks Rory
    Single wire sensor is the gauge in the dash, 2-wire sensor goes to the ECM. Gauge sensor will not affect engine performance, ECM sensor will.
