Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Dec 2016
    Default Blower not working, trips breaker when turned on
    Hey all, I searched but could not find anything addressing this.
    I have a 2012 Moomba Mojo 2.5 with 100 hours. The blower will not turn on and when the switch is turned on, it trips the fuse breaker. Does this mean I need to replace the fuse or does this mean I have a loose wire/failed blower?
    Thanks in advance.
    Bryan
    Indmar Assault 333
    May 2013
    Lake Anna, VA
    Disconnect at the blower and turn it on again. If it doesn't trip you are looking at a new blower most likely. There is no load so it isn't a perfect answer but at least means you have no short before that point.
    2007 XLV Gravity Games
    1,100 in each rear locker
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
    Mar 2003
    s.e. washington state
    If you find it is the blower, check inside the housing for debris that may have locked it up.
    Dec 2016
    Sorry for the noob question but when I disconnect from the blower, I'm disconnecting one or two wires? Do I just leave them loose or connect them to complete the circuit?
    Thanks in advance.
    Indmar Assault 333
    Apr 2017
    Hayden Id
    one wire would be enough to tell if it was the blower or not, if your breaker pops with one wire disconnected, the problem is downstream.
    2017 Craz surf auto wake
    1140 # rears wet sounds
    Dec 2016
    Will do this weekend. If it does not trip, does that mean its battery side/fuse? If so, where can I order a fuse?
    Also, maybe related, maybe not, my depth gauge works but shows ---. Is this a transducer problem?
    Thanks for all the help!
    Indmar Assault 333
    replaced 3 blower motors on my 2013 LSV. water would get into the blower motor and rust it causing increased resistance causing the breaker to trip.
    simple replacement
    Apr 2017
    Hayden Id
    If it does not trip with the blower wires disconnected, then it's the blower motor, chances are that is what it is, moombadaze is spot on with what usually happens. Not sure on your depth gauge, I see that same --- a lot ,every depth gauge that's been in 3 different new boats , the only time they seem to read is when sitting at an idle,
    May 2013
    Lake Anna, VA
    My depth was off and on last year. I found the thru hull transducer had come unglued which is a common problem. Check for that. Not sure if yours is thru hull. I epoxied mine in again this season and it has been rock solid so far.
    Your breaker is probably fine most likely.
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
    Dec 2016
    Thanks a ton for the replies! Very helpful community here! We are heading up this weekend and I will take a look at both of these.
    I am having trouble finding a schematic of where the blower is. Can someone show me a pic or describe where it is in the engine?
    Thanks,
    Indmar Assault 333
