Results 1 to 10 of 10
06-17-2017, 10:40 AM #1Junior Member
- Jun 2017
- 7
Anyone know what this rubber bushing is called???
Hey brand new Moomba owner here. I've got a leak and am trying to figure out what this part is called. Looks like an easy fix but I'm not sure how to find the part. Any help is appreciated!IMG_7740.jpg
06-17-2017, 10:43 AM #2Junior Member
- Jun 2017
- 7
IMG_7736.jpg the white rubber ring leaking water
06-17-2017, 04:26 PM #3
That's the impeller housing gasket
You can get a new one with your impeller or you might be able to order just that from Atlanta Marine
Sent from my iPhone using TapatalkMalo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-17-2017, 05:39 PM #4Junior Member
- Jun 2017
- 7
Thanks mmandley. I did a quick search and keep coming up with Johnson parts when searching indmar impeller gasket or raw water pump gasket. Do you know if this would be comparable this the oem part?
06-17-2017, 08:14 PM #5
Johnson 09-812B
Many places to get them. I think I've bought them from Amazon before
https://www.bakesonline.com/detail.aspx?ID=276Matt
2021 Mojo
2016 Mojo (sold)
2012 LSV (sold)
06-18-2017, 09:32 AM #6
Woody is correct
I carry a spare in my boatMalo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-18-2017, 04:25 PM #7
I suspect the cover was not on tight for it to blow the gasket. Make sure you can tighten the screws and that they are not stripped
09 21v LAUNCH
99 Outback LS. Sold
Doug
06-18-2017, 09:36 PM #8Junior Member
- Jun 2017
- 7
DOCDRS- that is exactly what happened. The top screw was loose causing it to leak. I tried to tighten it and the screw just spins. I tried to use a different screw just in case and the same thing happens. So now i am looking at replacing the whole raw water pump unless anyone has a solution. Any help is appreciated!
06-19-2017, 08:13 AM #9Senior Member
- Sep 2005
- Claytor Lake, VA
- 599
It doesn't look like there is enough metal to install an insert or tap to a larger size but you can try. If you buy a new pump make sure it is for 1-1/4" hoses, not 1".
2005 Mobius LSV
325 EFI
06-24-2017, 01:18 PM #10Junior Member
- Jun 2017
- 7
For anyone who has this same problem, I was able to tap from a 5mm to a 12-24, which was the closest size up I had. I had to buy a longer bolt and chop it down to fit but so far the gasket is sealed and holding strong. I'm still considering just replacing the pump to be safe but I've ran the boat hard for a few hours and no leaks so far. Reading the threads in here it seems changing the pump is pretty simple but can be a pain to get the old one off.
Thanks everyone for the info and help!
