Results 1 to 10 of 14
Thread: Thoughts on wakeboard set up??
06-15-2017, 07:40 PM #1
Have only surfed for the last several years. Have some wakeboarders coming up this week. Looking for weighting and speed recommendations.
2011 Mobius LSV, V2 Tower, 1100lbs regular side,
750lbs goofy, 370lbs ski locker, 750lbs bow,
flow surf (don't use it thanks to suck gate)
06-15-2017, 08:14 PM #2
How ever much you choose to weight the boat, which is usually determined by the rider's skill level, a good rule of thumb is evenly distributed port to starboard and 60/40 tail/nose for your ballast. You want the wake to wash out just behind where the rider is hitting the wake. That's usually determined by rope length and speed. For example, 65' usually cleans around 22-23 mph. Slower for shorter, faster for longer. This gives the rider the best opportunity for the most lift at the wake because there will be a little lip at the top.
When the rider is directly behind the boat you want both wakes clean. If one is washing, move the bodies in the boat to evenly distribute the weight.2016 Craz
1979 Ski Nautique
06-15-2017, 09:59 PM #3
What he said.
Sent from my iPad using Tapatalk2017 Moomba Craz
06-15-2017, 10:54 PM #4Member
- Feb 2017
- New Braunfels, TX
- 73
For skilled riders, I'd say 750 full and the other side 1100 as close to matching that as possible with center and ibs full. Use the trim tab to clean it up and around 23 mph. I've only had my lsv a few months but she's temperamental to side to side weight imbalances so adjust people as needed or increase speed as needed. If new riders all ballast empty and 19 mph with trim tab down to clean it up... If still washed out some front weight will help or increase speed.
2009 Moomba LSV
06-16-2017, 10:15 AM #5Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
I'm riding the Mojo at 70' at 23.0 MPH. Wave is clean there if folks in boat are balanced as needed. I'm putting say 1/2 to 3/4 full in the rear 1100's and center/IBS at 50% to 75% as well.
2016 Mojo Surf
Raptor 400
1100 rear bags / 500 IBS / 600 LeadWake
Exile amps/tower - Kicker in-boat
FAE
06-16-2017, 01:23 PM #6
06-16-2017, 01:27 PM #7
Thanks guys. Very helpful
06-16-2017, 06:36 PM #8Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
2016 Mojo Surf
Raptor 400
FAE
06-16-2017, 07:38 PM #9
Don't know what boat you have but I like to slam my Mojo. I run full ballast back prob around 1100 each plus I have 500 lbs lead weight 250 each side. I like the wake steep so I have wakeplate all the wake up. In order to do that ibs and front tank full plus I throw my extra bag up there. We run about 23mph at 65/70
Sent from my iPhone using Tapatalk2016 Mojo
2010 Moomba LSV-Sold
06-16-2017, 07:46 PM #10Member
- Feb 2017
- New Braunfels, TX
- 73
