Results 1 to 6 of 6
06-14-2017, 09:53 PM #1Junior Member
- Oct 2016
- Wichita, KS
- 25
Question on Ballast Bags and speed???
I have a surf edition 2015 Mondo that I just picked up over the winter. Just getting it out an starting to mess with surfing and ballast bags. When I have all the bags full, I can give full throttle and it goes to about 10 and then could pick up a little speed, but not much. Is that normal? I was trying to use the cruise control for surfing, but does not appear I have any option on my speed.
Thanks2015 Mondo
Aviator Tower
06-15-2017, 11:15 AM #2
It sounds like your cruise control is set to 10. Have you tried adjusting the cruise with the lever on the right hand side of the steering wheel? That is how you adjust the cruise control while moving. You can also set the cruise through the dash before you get started.
2016 Mondo Surf Edition
06-15-2017, 11:18 AM #32015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
06-15-2017, 11:52 AM #4
So the 15's do not have the cruise lever? Sorry, my 16 has that and I assumed all the Mondos did.
06-15-2017, 11:56 AM #52015 Mondo
2079 Prop
Auto Flow 2.0
06-15-2017, 12:23 PM #6Junior Member
- Oct 2016
- Wichita, KS
- 25
I have the digital cruise pro II and don't have a lever, I have to do it from the computer screen. However, my cruise was not engaged, it was off....but sure acted like cruise was on.
2015 Mondo
Aviator Tower
