Results 1 to 6 of 6
    Oct 2016
    Wichita, KS
    Default Question on Ballast Bags and speed???
    I have a surf edition 2015 Mondo that I just picked up over the winter. Just getting it out an starting to mess with surfing and ballast bags. When I have all the bags full, I can give full throttle and it goes to about 10 and then could pick up a little speed, but not much. Is that normal? I was trying to use the cruise control for surfing, but does not appear I have any option on my speed.
    Thanks
    2015 Mondo
    Aviator Tower
    Mar 2013
    Wisconsin
    It sounds like your cruise control is set to 10. Have you tried adjusting the cruise with the lever on the right hand side of the steering wheel? That is how you adjust the cruise control while moving. You can also set the cruise through the dash before you get started.
    2016 Mondo Surf Edition
    May 2014
    Palm Desert, CA
    Quote Originally Posted by coneslager View Post
    Thanks
    Quote Originally Posted by klemmy View Post
    To adjust your cruise on your 15 you need to use the up/down arrows on the screen
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Mar 2013
    Wisconsin
    So the 15's do not have the cruise lever? Sorry, my 16 has that and I assumed all the Mondos did.
    May 2014
    Palm Desert, CA
    Yeah they changed to the lever in 16. I wish mine had the lever haha
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    Oct 2016
    Wichita, KS
    I have the digital cruise pro II and don't have a lever, I have to do it from the computer screen. However, my cruise was not engaged, it was off....but sure acted like cruise was on.
    2015 Mondo
    Aviator Tower
