Results 1 to 10 of 10
    Jul 2013
    Wisconsin
    Default rough water driving
    Yesterday the winds on my lake went from about 8 mph to almost 30 mph in an hour or two. Unfortunately to get back to the truck i had to head into the wind, so i ended up facing off against 2 ft white caps in my 08 LSV. After a 15 minute beating, i gave up and went to a different ramp, got a ride around the lake to the truck and drove around to pick up the boat.
    What are some tips for rough water driving or is there just no hope for our smaller boats? My thought was to get the bow up to keep water from coming over the bow and go about 10 to 15 so it isn't super intense on the boat but any slower and the nose wouldn't have been high enough for when i rode down the wave and into the next. I tried all kinds of angles of attack and none seemed to work. The boat was pounding waves and water was spraying everywhere. I actually had concerns of the gel cracking from hitting waves or the boat getting too much water on board and sinking. It took some time for my adrenaline to calm down afterwards...
    2008 LSV. 1100 rear sacs and IBS. ACME prop is next
    Ronix One w/ Parks bindings
    Aug 2011
    Commerce Lake, MI
    At 10-15 you're not on plane, and that will beat the hell out of you.
    2017 Moomba Craz
    Jul 2013
    Wisconsin
    I read on another forum guys with small fishing boats get up on plane and basically skip across the waves. That seems unstable to me but I'm used to small lakes and have never had to deal with larger waves
    Mar 2014
    Park City, Utah
    There are so many responses and varied opinions you can get from this. Here is a video from Lucky Peak just east of Boise from Sunday the 4th.
    https://www.youtube.com/watch?v=pgn4...&feature=share
    it's long but observe the Malibu, what did he do right in this situation vs. what did he do wrong?
    First, if the water is choppy, all passengers should have a life jacket on.
    Second, if you had any ballast bags full, empty everything as quickly as possible.
    Third, get all passengers out of the bow. Move the weight back.
    After that it's just getting through, in my LSV we would raise the wake plate up all the way to help get the nose up. Obviously I was not there and can't give details, but to me, 10-15 is too fast, try taking the waves from an angle rather than straight on, in some cases you're better off to find a cove or some protected area and wait it out, sounds like you did something similar and found a dock.
    Back to the video, compare the Malibu to the Yellow Speed boat with 6 inches of bow rise.
    2017 Centurion Ri237
    2013 Supra SA450 - Sold
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    May 2014
    Palm Desert, CA
    I have to plow as well. Last time I filled my hard tank thinking it would help cut through a little better. I couldn't really tell if it helped or not cause I didn't have to go far so it probably didn't fill much of it anyways. My Mondo beats the crap out of me sometimes though
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Mar 2003
    Springfield Missouri
    There is only one right answer if you have to travel during high wave action and that first all occupants including the driver don life jackets, snap on the bow cover and drive the boat at a high angle of attack. The best answer is to find a protected cove and wait it out or do as you did and get the trailer. Things can get messy and there is no need to put everyone in a position that they never needed to be in.
    1998 Mobius
    310 HP PCM
    SOLD
    Aug 2011
    Commerce Lake, MI
    Hitting the waves at 45° helps a lot too.
    2017 Moomba Craz
    Mar 2017
    Edmonton, Alberta Canada
    ^^^ Stazi is correct. If you gotta head into the wind, you should maintain 45 degree angle and zig zag through the waves. My dad/grand dad call it "running off". I believe the proper term is "running the trough"
    Best option if possible though is to find a cove or calm area and wait it out.
    2002 Supra Santera (SOLD)
    2017 Moomba Mojo Pro Vivid Orange
    (1595lb wakemakers in the lockers)
    May 2016
    West Milwaukee, WI
    Sheltering in a cove is best if you can wait it out. Also get passengers out if possible.
    Otherwise, don lifejackets, drain ballast, then head out slowly at an angle to the chop. The boat will be constantly rolling and pitching, but you'll keep most of the water out of the bow this way if you don't have a bow cover. You might have to zig-zag a bit to get where you're going.
    This is pretty easy to practice in calm water by loading your ballast, get to surf speed, then turn right around into your own wake and find the attack angle that keeps the most water out.
    2004 Mobius LS - hooked on footin'
    Former tow: 1986 Chaparral 178 XL, 90hp Merc
    First tow: 197x Glasspar Citation, 135hp Merc
    Good advice here already. I haven't run into really rough waters with my lsv but I did once on lake Mojave in my tige. The swells had to be at least 3 feet and they were spaced perfectly so that i was taking on a lot of water over the bow. I set the wake plate all the way up to get the bow as high as possible and putted at about 8mph or so. That was the only way to keep from flooding the boat. And it was a rough 12 mile trip to the marina that day.
    The only time I've run into any weather in my lsv was this year on lake pleasant near Phoenix. It was windy but the chop was probably only a foot or so. With the water that relatively flat the boat did best around 20-25 and it kept water from spraying everyone on board.
    So I guess what I'm getting at is it depends on the situation. Always err on the side of caution and, as everyone has already said, if you get to the point where you're uncomfortable then find a cove and wait it out!
    Tow Vehicle 2003 F250 6.0 PSD
