Results 1 to 8 of 8
Thread: Ballast leaking from air valve
06-09-2017, 09:25 PM #1Junior Member
- Sep 2016
- Minneapolis MN
- 24
Rookie here. 2016 Craz. Do I need to open the top valve each time to allow air out then close them to avoid leaking? Was out today after dealer fixed leaking bag and they mentioned the adjusted the valve to the right spot whatever that means. I just know I can see the water coming out so I closed them tight.
The bags are not stock. they are the 1100 bags I had the dealer upgrade.
Any advice for the noob?
06-09-2017, 09:30 PM #2
Not sure what your asking. The top hose should be he overflow when the bag is full and will dump out the side. Maybe the dealer meant he rotated the hose so it wouldn't get pinched between the bag and the side of the hull as it was filling and get blocked Mine has done that a few times until I twisted the hose around. You shouldn't have to burp the bags every time you fill.
Sent from my iPhone using Tapatalk2017 Moomba Craz
06-09-2017, 09:54 PM #3Junior Member
- Sep 2016
- Minneapolis MN
- 24
Thx. On the top of the bag there is a vent, no hose attached just a vent. They were leaking and not fully tightened. I'm assuming they should be closed as there must be another overflow hose vs. the vent I'm seeing on the top. When I tightened them down they clearly stopped leaking. I'm assuming that's all I need to do?
Also, I've never seen water come out of the side of the boat for "overflow". Should I keep filling? Thx all
06-09-2017, 11:06 PM #4Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
Yeah, if run pumps longer than timer allows (meaning you turn them back on) all ballasts should eventually overflow and pee out that side.
Sent from my iPad using Tapatalk2016 Mojo Surf
Raptor 400
1100 rear bags / 500 IBS / 600 LeadWake
Exile amps/tower - Kicker in-boat
FAE
06-09-2017, 11:11 PM #5
You should have one over flow hose on the top and possobly an extra vent/connection point that you don't really use.
06-10-2017, 08:45 AM #6
Got any pictures,
The air vent should be closed as Stazi said ,should have a vent hose attachedA Day at the Lake...Priceless
06-10-2017, 11:40 PM #7Junior Member
- Sep 2016
- Minneapolis MN
- 24
I'll take some pictures. Today I closed them up and I didn't have any leaks but the bags did fill with air quite a bit so I let some air out and closed them again. All good. Now I need to get this goofy wave figure out. I'm a goofy rider and the wave sucks compared to the other side.....
06-11-2017, 09:08 AM #8
think your going to have to list it slighly on the goofy side.
we had to on the mojo pro as wellA Day at the Lake...Priceless
