Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Jun 2017
    Default Just bought a '15 Mondo!! Need advice!
    Well, this is my first post and my first wake boat. I snagged a good deal on a 14 hour '15 Mondo with the surf package. Dual 650's in the back lockers, 500 center, 500 bow, and manual flow surf. Keep in mind this will be my family's first year trying to surf. Will I get a decent wave filling 100% of the stock ballast and dropping the opposite side gate? I know I'll need to play with the wake plate, speed and positioning of people in the boat, I'm just hoping I will be able to get away with the stock setup for now. I still need to buy a rope and a couple boards and even though I got a good deal it was still expensive up here in Canada.
    Thanks for any help.
    May 2015
    North Carolina
    You will need to list to surf side a little. Then when you can increase rear bags to at least 900. Take some time and just try different setups.
    James
    2014 Mondo
    93 Four Winns 180 Freedom Sold
    Jun 2017
    Quote Originally Posted by JD14Mondo View Post
    Is it typical to fill all 2300lbs. and then throw a few people to sit on the surf side of the boat?
    May 2015
    North Carolina
    I have 900 rear and 750 IBS. Fill non surf side about 80% and adjust with crew. Seams like goofy side likes more lean than regular side. Put manual flow all way down. Run about 10.8 regular and 11.8 goofy. Use wake plate to fine tune. I had 600 before the 900 and it was okay. But for max wave you will need more weigh in the rear. Just be patient and try different settings. Have fun and be safe!
    James
    2014 Mondo
    May 2014
    Palm Desert, CA
    Congrats man! Where's the pics though? If you're not using Tapatalk then you should. If you didn't know now you know 🏼*♂️
    I have 15 Mondo with AutoFlow 2.0
    900rears 250under port seat piggy backed off port bag & 750ibs.
    Wave is killer! The more weight you add the better it will get. I would suggest upgrading ballast before your next trip. Easy swap out & easy to adjust ballast fill times. Get the 1140 bags from wakemakers & 750ibs. Don't even mess around with stock....TRUST ME
    FTW
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Jun 2017
    Here it is. I'm pretty excited to say the least!!
    May 2014
    Palm Desert, CA
    Looks good!!
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    Aug 2015
    Ohio
    That my friend is a good looking Mondo!!! Congratulations
    Quote Originally Posted by pat6969 View Post
    2014 Mondo
    2013 Yamaha AR192.... Long gone
    Jun 2017
    Thanks guys! Just picked it up today and it looks great. Can't wait for the maiden voyage next weekend!
    Jun 2017
    So, I was in my Mondo Surf Edition checking out all the functions and familiarizing myself with it overall. I noticed it only has 3 switches for ballast fill and drain. I was told this boat had a 650 in each back corner, a 500 center and a 500 bow. How does this work? Does the front pump fill the center and the bow together?
