Results 1 to 10 of 20
Thread: OBD2 Port
    May 2017
    Default OBD2 Port
    Do these boats come with the ability to read error conditions?
    2015 Mojo Surf
    Yes
    But it requires a special connector and software. It's a scanner like your car
    [COLOR="#696969"]
    Oct 2010
    Lake Wylie NC Area
    Boats do have OBD but not the standardized OBDII
    May 2013
    Vancouver WA
    Yeah, the code readers are pretty much specific to the marine industry and tend to be prohibitively expensive. The cheapest one I found was hundreds of dollars. It just didn't make sense.
    And for the newer boats, the display screens tell you the error codes and descriptions anyway, so it's reading it's own codes...
    www.TraysonsToybox.com
    May 2017
    These are basically truck engines, wonder what the reason is for leaving something east like a OBD@ off? so you're captive to the dealer?
    2015 Mojo Surf
    Oct 2010
    Lake Wylie NC Area
    Quote Originally Posted by SorryCharlie View Post
    If you know why we have OBDII on light duty vehicles, you will understand it was not left off of boats. OBDII was federally mandated. Even prior to OBDII, you could still purchase an aftermarket scan tool and interface with OBDI on quite a few of the auto maker's system. However, some, most were the imports, kept their protocol proprietary. With that said, there is nothing preventing you or anyone from purchasing the software/cable and interfacing with your MEFI engine system. You are only restricted by your wallet.
    May 2013
    Vancouver WA
    MLA is correct. I'm pretty sure that I have MEFI 5 on my CAT 340 ETX engine. so that means for "only" $500, I could get this:
    https://www.obd2allinone.com/mefi5scan.asp
    May 2017
    Federally mandated or not, I can read the code on my truck for $20 and have a general idea of what the issue is.
    You're in luck, it's down to $350
    2015 Mojo Surf
    May 2013
    Vancouver WA
    $20 = economies of scale/supply and demand. Just like the availability of Marinized parts for our engines...
    May 2017
    Tell me about it, fuel pump $800
    2015 Mojo Surf
