Thread: Ballast fill times'17 Craz
05-28-2017, 08:26 AM #1
Just curious as to what times everyone is using on the ballast fill times. I have the surf package with the 900 in the rear and the bow sack. It came with 9min fills for the rear I changed that to 9:40 and they still don't get to 100% the front was 11min and the same. Does anyone know what time they should be set at so when it hits 100% the water start coming our the vent tubes.
Thanks guys2008 LSV on the way out
'17 CRAZ!!! on the way in
05-28-2017, 09:01 AM #2
You'll have to time it. I know most guys go roughly 1 min per 100 pounds, but that can change based on impeller condition.
Sent from my SM-G900W8 using Tapatalk2016 Craz.
Enzo bags.
05-28-2017, 10:02 AM #3
That's what I did. I use the stopwatch and timed how long it took to fill in empty the bags and then set those times in the computer
Sent from my iPad using Tapatalk2017 Moomba Craz
06-03-2017, 10:37 PM #4
So I figured out today that you can actually change the surf tab level on the 2017 Autowake 2.0!
When you are in auto wake mode you use the up down arrows to change the surf tab percentage up or down by 5% increments! You can also adjust the wake plate. I found the best setup for My Craz with 1100's per the pic below
Sent from my iPhone using Tapatalk2017 Moomba Craz
