Results 1 to 10 of 13
Thread: Won't start
    Mar 2017
    Madison, WI
    Default Won't start
    Second time out on our boat. Started fine at the doc, but we shut off in the middle of the lake and it did not start. We thought that maybe the battery was the problem at first. Our friends on lake happen to have a new extra battery with them. We hooked up and nothing. They were auto mechanics and found the solenoid and were able to fire it up. Any ideas what could be wrong? They thought maybe a relay?.
    Neutral safety switch? You try moving the throttle back and forth a few times then making sure it clicked into neutral?
    Tow Vehicle 2003 F250 6.0 PSD
    Mar 2017
    Madison, WI
    I did try that several time and no luck. Also tried messing with the safety switch below the throttle.
    If you were able to start it by bypassing the ignition and going straight to the starter then most likely your neutral safety or emergency kill switch is your problem
    [COLOR="#696969"]
    Nov 2013
    West of ATL
    What year boat? On our '08 we had an issue like yours and it turned out to be a worn out ignition switch.
    2008 LSV on the way out
    '17 CRAZ!!! on the way in
    Mar 2017
    Madison, WI
    Quote Originally Posted by Rakkasan View Post
    It is a 2014. I feel we bought a lemon
    Mar 2017
    Madison, WI
    Quick update..... the boat now turns over when I tried in the garage. Now I have no clue.
    Oct 2013
    Ft. Collins, CO
    This really sounds like either the neutral safety switch or the dead-man switch. I'm not sure about the '14 trannys but the older NSS could be adjusted and would be touchy if not right. The dead-man switches can be finicky. Neither would lead me to think lemon.
    1989 Sanger Skier DX - sold
    Mar 2017
    Madison, WI
    The dealer thinks there was some type of error code and resetting the main breaker for a minute will reset and allow to start. They think this was a fluke. Going to get a second opinion tomorrow
    Jul 2002
    London Ontario Canada
    My 09 has a wonky ignition switch. You can always hotwire the switch to determine if thats the culprit
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
