Results 1 to 10 of 15
    Jun 2013
    Default Electric Shock Drowning
    A friend who knows that I spend a lot of time on our boat in our lake sent me an article on FB about electric shock drowning (ESD). I had never really heard of this before and thought there may be others out there who may also benefit from this information. The link below has a very informative article on the subject.
    I am very much a novice when it comes to electricity, but from reading the below article is sounds like the only real problem is with AC coming from shore power of some kind. This is likely why I have never heard of the issue before because our lake is very small with no marina and the only shore power I have at the dock is the occasion extension cord for the battery charger that needs to be hooked up from time to time.
    http://www.boatus.com/seaworthy/maga...-explained.asp
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Oct 2013
    My wife watched her cousin die when she was younger from the same thing. Swimming off the back of a houseboat and the shore power had a wire exposed
    Jul 2010
    Vicksburg, MI
    One of the best things to do is make sure that every extension cord is plugged into a GFCI and check the operation of the GFCI on a monthly basis.
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    Great thread! Thanks for sharing. I had not heard of this either despite a lifetime of being on the water.
    Jun 2013
    Quote Originally Posted by jstenger View Post
    That's the approach that I always take, but I was never sure if that was enough.
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
    Mar 2003
    Springfield Missouri
    Quote Originally Posted by mikenehrkorn View Post
    It's not. The GFCI should always be tested before use to get the optimal protection which is especially important if working near water. GFCI's have a high failure rate and seldom do they fail in the open (powered off) position. I've seen a failure rate of 5-10% per year of the GFCIs at our work site. Motors are not connected to GFCIs as the transients on start up or their motor starter will trip them so avoid water contact at marinas where the fuel pump is on the dock. The same can be said about motors for boat lifts and ensure the wiring is in good shape and protected from damage. Have a power disconnect on shore and disconnect the power on shore when the lift isn't used. Proper grounding (bonding) is the key as electricity is always looking for the easiest return path. If you continually trip a GFCI, there is more to the story than you want to believe so you need to find the culprit whether it is the extension cord or the device being used. The testing device in the article is inexpensive, easy to find incorrect wiring and has a trip device for GFCIs that puts an external fault to the receptacle that would replicate an actual incident. I carry one when I use a campground to make sure the their wiring is correct. BTW, May is Electrical Safety Month so a great time for the subject.
    1998 Mobius
    310 HP PCM
    SOLD
    I used a gfci fault break testers well
    There is a warning device sold that will pick up stray electricity in the water and set off a visual and audio alarm
    http://www.docklifeguard.org/purchasehere.html
    We always unplug our dock hoist power when swimming kids and pets
    Arkansas
    There are a couple variations of what Joe posted. My wife has been looking at them but we haven't bought anything yet. Would love feedback if anyone has used one.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Mar 2016
    Birmingham Al
    This happens near me every season. Had two drown last year at my home lake. Sad stuff..
    Kyle
    My buddy just bought one I will give you feed back on the one posted above
