Results 1 to 10 of 20
05-10-2017, 09:25 AM #1Junior Member
- May 2017
- 13
idle to wide open throttle boat stalls at about 3000 rpm's
need help
from idle to WOT my boat stalls at about 3000 rpm's for 1 to 2 seconds but recovers and runs fine, also runs fine
the rest of the time.
drained tank refueled with high octane non ethanol
replaced fuel filter
replaced water fuel filter
replaced TPS sensor
1998 MOOMBA OUTBACK
515 HOURS
INDMAR 350 GEN 1 PLUS EDL MPI ENGINE
05-10-2017, 09:26 AM #2
When your below 3k is it smooth and responsive?
When is the last time you changed plugs, wire, cap and rotor?
Sent from my iPhone using TapatalkMalo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-10-2017, 09:37 AM #3Junior Member
- May 2017
- 13
runs smooth and responsive other then when idling for long periods it
will surge sometimes.
haven't changed plugs, wires or cap and rotor
05-10-2017, 09:53 AM #4
I would start with those items
After that your prolly having issues on your carb secondary jets or plates
If you can have someone drive so you can see if the secondary butterflies are opening on your carb
You might be running super rich over 3k
Black or wet spark plugs will show that as well.
If butterflies are opening you might be having jet issues. At WOT you should see fuel spraying.
[COLOR="#696969"]
05-10-2017, 10:19 AM #5Junior Member
- May 2017
- 13
the 350 MPI is efi, but my next step was to change those items thanks
05-10-2017, 10:47 AM #6
First I learned Moomba used EFI in the 98s. I knew they offered both PCM which I have and the Indmar engines and that may be the reason. Besides what Mike mentioned, I would recommend running Seafoam through the fuel system.
1998 Mobius
310 HP PCM
SOLD
05-10-2017, 12:30 PM #7
Sorry missed you had EFI lol
[COLOR="#696969"]
05-31-2017, 01:57 PM #8Junior Member
- May 2017
- 13
any body??????
need help
replaced TPS sensor
replaced spark plugs, cap and rotor
1998 MOOMBA OUTBACK
515 HOURS
05-31-2017, 02:23 PM #9
WOT on the three boats i have owned is higher than 3,000 rpm. What does it do at 4,000?
Other thought was fuel, but you're already using what I would recommend, have you burnt through a full tank of the good stuff yet? Maybe second full tank will be better?2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
05-31-2017, 02:39 PM #10Member
- Aug 2016
- 98
I m thinking if the system uses a mass air flow sensor then as you accelerate it will not know the correct air flow and not provide spark and fuel properly
