Results 1 to 10 of 12
Thread: 2007 LSV Trailer Jack
05-09-2017, 10:19 PM #1Member
- Mar 2017
- 76
I have a 2007 LSV and was wondering if others are able to crank their trailer jack up high enough to get the water in the ski locker and bilge to empty out of the rear drain plug.
05-09-2017, 11:45 PM #2
Mine won't go high enough for that. I have a sloped driveway so I have to nose the truck into the garage with the boat hooked up to get enough incline to drain all the water
Sent from my SM-G930V using Tapatalk2007 Mobius LSV
Tow Vehicle 2003 F250 6.0 PSD
05-09-2017, 11:49 PM #3
I have never gotten any water to drain out of my drain plug. When we first got the boat, I even pulled the plug out while still on the ramp for a severe slope and didn't get any water out that way either. I mentioned it to my dealer and he told me it's a flaw in the design of this model boat. Apparently the drain plug sits above a shelf in the back of the boat. Because of this, it's not the lowest point or even close to the lowest point in the boat. Hopefully somebody else can confirm this or has better knowledge of our model boat than I do but again, that's what my dealer told me.
twkoehn
1100s in rear lockers
750 lb IBS
Acme 1847
05-10-2017, 06:42 AM #4
Yea, there is no use even pulling the drain plug unless your boat is going to sit where rainwater can get in. I always seem to have a little water down there so I add soap/simple green to my bilge to keep it from getting too bad. Kinda self cleaning when you do that.
05-10-2017, 06:52 AM #5Member
- Mar 2017
- 76
Thanks for the reply guys. Simple green is a good idea. So you just don't worry about a little bit of water in the bilge/ski locker then? Is it worth trying to get the residual water out w/a towel?
05-10-2017, 07:22 AM #6Senior Member
- Oct 2004
- Middle TN
- 148
05-10-2017, 07:31 AM #7Member
- Feb 2017
- New Braunfels, TX
- 73
05-10-2017, 07:58 AM #8
It's so hot in my garage in the summertime most of it evaporates anyway. I'll shop vac out from time to time if I have to do anything in there.
05-10-2017, 08:36 AM #9Member
- Mar 2017
- 76
With your boat on a slope, you can get the water out? Thanks
05-10-2017, 10:31 AM #10
Not all of it. But I can get enough out that a shop vac and a towel make quick work of the rest. Had to do it when I did the wakemakers pump upgrade so the sealant for the thru-hulls would dry properly.
Makes sense that there's some kind of shelf in the bottom of the boat that doesn't allow water to get to the drain plug. I never get any out of the plug when I pull it on the ramp and there's always a bit in the bottom of the boat. I like the simple green idea too
