Results 1 to 5 of 5
Thread: Craz IBS weight
05-16-2017, 11:27 AM #1Member
- Jan 2016
- Lake Blackshear, GA
- 40
Craz IBS weight
I have the 500 lb IBS in my Craz, but I have upgraded the rears to Enzo's 1450 lb on each side. Wondering if anyone has tried a bigger IBS and how big I could go up there. Would love to try to keep the weight under the seats if possible. I'm also considering lead. Currently throwing a 400 lb sac up front which works pretty well but takes up space...
Sent from my Pixel using Tapatalk2016 Moomba Craz
Boards:
Day 1 Wake Payne Killer
Doomswell Drone 4'10"
Phase 5 Diamond
Hyperlite Quad
Lakewakes Hooligan
Phase 5 grom
CWB Razr
Tubes:
Sombrero
Bandwagon
05-16-2017, 01:28 PM #2
I don't think a bigger bag will fit. The stock one pops out the drink holders when it's full.
Sent from my iPad using Tapatalk2017 Moomba Craz
05-16-2017, 01:38 PM #3Member
- Jan 2016
- 40
Yeah that's why I'm wondering if a bag with a different shape will fit, maybe longer arms or something? I just leave my cupholders out and the bow cushion in... Curious if anyone has tried any different bags. There is a 750lb sumo sac and a 950lb axis sac on the wakemakers site. I guess another option is just a triangle shaped sac that would sit down in the playpen area a little better...
Boards:
Phase 5 Diamond
Hyperlite Quad
Lakewakes Hooligan
Phase 5 grom
CWB Razr
Tubes:
Sombrero
Bandwagon
05-16-2017, 03:48 PM #4
Get a 400lb tube and put it in the walkway as far forward as you can. That what we do. I have 2 from when I had my 2004 LS, plus I have a 750 that we sometimes use on the back seat of my buddy's XLV. The bow bag in the Craz from the factory is as big as you can go.
05-17-2017, 09:08 AM #5
If I was you, I'd get about 400 lbs of lead/steel and put it under the bow filler. I used a sac in my walkway last season and it damaged the gel coat in the walkway. This season I'm running 200# of steel under my bow sac and plan to put another 200# steel under the bow filler cushion. I can tell you, that I am definitely light on the bow weight as is. Push is incredible with the enzo's though.
Sent from my SM-G900W8 using Tapatalk2016 Craz.
Enzo bags.
