Results 1 to 10 of 45
Thread: Flag pole
05-09-2017, 08:55 PM #1Junior Member
- Jun 2016
- 26
Flag pole
So I had a custom flag made its a 3'×5' but I'm having trouble finding a pole that will mount to the tower any suggestions?
13 moomba mobious
05-10-2017, 07:16 AM #2
I use these, I also have a 3x5 Flag I fly all the time.
This has several mounting points for the pin to hold it in place making it easy to get the perfect angle for your flag.
https://www.bulletlines.com/Wakeboar...lder-p/799.htmMalo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-10-2017, 08:26 AM #3
I made my own using flat and round tube steel. Put a little angle on tube then welded to flat steel, removed speaker's drilled holes in flat to match speaker mount holes then sandwiched holder between speaker and tower. Wanted something high on tower that would not interfere with bimini. My welding is not the best so i think i might have a shop make some with aluminum.
Sent from my SM-G935W8 using Tapatalk2016 Craz
05-10-2017, 12:49 PM #4
I have the same flag holders that Mike has (although I think they're cheaper on Ebay).
For poles, I actually found some gray plastic tubing that would be used for irrigation or plumbing. I got it at home depot. it's pretty rigid, with just a little bit of flex to it. I put some caps on the top to give it a smidge more of a finished look. It was super easy to drill holes in the plastic pipe and use zip ties to mount the flags.
I've since moved my flag mounts to not interfere with my overhead board racks... You can see the new flag location starboard vs the old location port.
www.TraysonsToybox.com
05-10-2017, 09:20 PM #5Banned
- Feb 2014
- My Moomba Lives in Eagle River, WI - We Live in Chicago
- 225
+1 on the Bullet Lines flag holder. It's easy to install, and allows you to lock the collar at different angles depending on where you mount it on your tower so you can get the flag pole vertical. I guess my smaller flag means I probably harbor a small amount of "flag envy" versus the 3'x5' flags that Trayson and Mmandley have, but I'll get over it
05-10-2017, 10:14 PM #6Junior Member
- Jun 2016
- 26
Alright cool thanks for the info a lot of good ideas I'll probably go with the bullet lines
13 moomba mobious
05-11-2017, 07:41 AM #7
Does anyone know what the diameter is on the A3 tower, going to order the bullet mount and don't know which size to order, thx!
Landon
17 Mondo Surf Edition
WS Rev 10's
05-11-2017, 07:55 AM #8
05-11-2017, 07:58 AM #9
05-11-2017, 08:04 AM #10
