Results 1 to 9 of 9
Thread: Won't take fuel
    Mar 2017
    Madison, WI
    Default Won't take fuel
    2014 mojo does not want to take fuel. I get a couple gallons in and it spits out of the hole. This was when I tried to fill at the gas station. I bought some gas can and the same results. Dealer say to try at the gas pump with handle upside down to force the fuel in. This seems wrong to me. Ideas?
    Mar 2014
    Park City, Utah
    Sounds like the hose going to the tank has a kink or maybe something has moved it slightly. Follow the fuel filler hose from the exterior all the way through to the tank and see if there is an issue with the hose.
    My Stingray would fill from the stern and the hose was at such a horizontal angel I had to fill super slow to prevent the gas from spitting back out, was just a dumb design in my opinion. Have had no issues with the LSV or SA.
    2017 Centurion Ri237
    2013 Supra SA450 - Sold
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    Mar 2017
    Madison, WI
    Is this a valve next to the gas fill that I can open to help vent while filling?
    That's the vent , doesn't open, should be auto
    Mar 2017
    Madison, WI
    I found a kinked hose near the vent. This could be the culprit. Probably need to put new hose in.
    You don't need a new hose unless you make it longer
    Get a peace slightly larger hose, zip tie it to the kinked section to keep the kink out.
    [COLOR="#696969"]
    Feb 2006
    Birmingham
    You could also just use a Gates Unicoil. I use them a lot on older bike builds where you cannot get replacement hoses but need a tight bend in a standard hose. I think they go to 1".
    http://www.jegs.com/p/Gates/Gates-Un...43357/10002/-1
    15 Mondo Surf Edition
    02 LSV - Traded In
    May 2007
    Richmond, VA
    Jesse - That Gates Unicoil looks to be a good solution. Hey, glad to see you are still here on the Forum. Hope all is well and you are enjoying the Mondo! - Stuart
    Quote Originally Posted by JesseC View Post
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    Feb 2006
    Birmingham
    Quote Originally Posted by deerfield View Post
    I have used them in several different applications.
    Doing well and trolling the forum every now and then. I absolutely love the Mondo it has been a great boat. Hope everything is going well for your crew!
    02 LSV - Traded In
