Results 1 to 2 of 2
Thread: 2007 LSV Cover
    Default 2007 LSV Cover
    Recently bought a 2007 LSV and waterproofed the boat cover, thanks to your suggestions. Another question I have is regarding the holes in the cover around the 4 tower mounts. The holes in the cover to allow clearance for the tower are fairly big. Has anyone used something to close these holes up? I spoke with a local boat cover maker and he said he could fix the problem for a few hundred dollars. Don't want to spend that on a 10 year old cover. Any thoughts? Thanks, Pat
    May 2010
    Salt Lake City, Utah
    don't know if this would work but depending on the size of the space you are trying to close you could buy some of the "pool noodle" ( those floating Styrofoam tubes you play with in the water). You can cut them up and place them around the tower where the cover goes and see if that will work? Just a thought.
    Scott
    2021 Craz
    1997 Sea Ray 190
