Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 68
    Nov 2014
    Columbus, Ohio
    Link please. I had one in my last boat but know that one wouldn't work on my new Craz
    Boatless for now
    Commerce Lake, MI
    http://m.ebay.com/itm/BLUE-LED-BOAT-...=1782738015002
    2017 Moomba Craz
    May 2014
    Palm Desert, CA
    My lake you can't tow with the drain plug in unless you want a ticket. I wonder where I could put it while towing so I don't loose it or scratch the shit out of my wake plate.
    Although $13 doesn't sound like it's going to be very bright lol
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Commerce Lake, MI
    The other one I bought for $20 was super bright. It wouldn't fit as it interfered with the wakeplate. Brett, why would you have to remove it while towing? Just dont turn it on. Plus can you tow at night anyway?
    2017 Moomba Craz
    May 2014
    Palm Desert, CA
    Towing on the trailer. My lake has a muscle issue so they want your boat completely dry if your towing to another lake.
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    Commerce Lake, MI
    Default Underwater LED's
    All of these lights have a quick disconnect so that you can remove them easily
    ETA: Looks like this second one I bought doesn't have the quick disconnect like the first one.
    2017 Moomba Craz
    May 2013
    If I did another drain plug light, I was going to install a quick electrical disconnect. (although that was going to prove tricky because I don't know if I would have been able to find a waterproof quick disconnect that would actually fit through the drain plug hole.)
    That said, I stopped that project and put my regular drain plug back in because while I was messing around with the drain plug light I dropped it on the garage concrete floor and cracked the epoxy... FML.
    I'm still trying to figure out what my ultimate solution will be... I've got a bunch of those 6w LED lights, but I still haven't figured out a solution for installing 8 of them without drilling 3 holes for each of them (wire, and two mounting screws).
    www.TraysonsToybox.com
    Nov 2014
    Columbus, Ohio
    Thanks. You're positive this fits without issue on the Craz?
    Boatless for now
    Commerce Lake, MI
    This is the one I bought first. It has a quick disconnect but doesn't fit.
    https://www.ebay.com/itm/121611407352
    2017 Moomba Craz
    Commerce Lake, MI
    This might be the ticket, but I am weary about galvanic corrosion between the chrome and bronze on the hull fitting.
    https://www.ebay.com/itm/171434177333
    2017 Moomba Craz
