Results 1 to 6 of 6
    Default Ballast bag, ski locker 2007 LSV
    We have a 2007 LSV w/ballast in each rear locker and the ski locker. The ski locker never seems to dry out as the empty ballast bag doesn't allow airflow, and is starts to smell. Anyone else have this issue? Any suggestions on how to dry it out, or just don't worry about it? Thanks
    Jan 2010
    North Texas
    Take the bags out after each use, shop vac the carpet, drop a small fan in the lockers.
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
    Feb 2017
    New Braunfels, TX
    The ski locker has an outlet hole to the bilge which can be plugged up and greatly reduce water in the ski locker. here is a thread with many good upgrades, post 29 demonstrates what i'm talking about. I ordered 1 1/4 plug but it was a little too small so i just wrapped it in several layers of tape to improve the seal but it was a little half assed but still works good.
    https://forum.moomba.com/showthread....my-08-LSV-mods
    2009 Moomba LSV
    Don't worry about it, take them out at the end of the season..No reason to remove or dry them. Pour some simple Green in there and the in bilge area and leave it. When you use the boat or trailer it it'll clean everything like a washing machine.... �� Make sure you dilute the simple Green otherwise you'll have a really clean spot..
    2006 Moomba Mobius LSV - Sold
    Salt Lake City, Utah
    I used to take my bags out of the ski lockers every time i got home and vacuum them out and leave everything open to dry. Then i got smart and removed the carpet in the rear lockers and replaced it with a seadek type of material so now i just lift up the bag a little and wipe it dry. It is so much easier not having carpet in the lockers.
    Scott
    2021 Craz
    1997 Sea Ray 190
    That was one of the first things I got rid of too. So easy to dry out now without carpet.
