Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Jan 2017
    Alabama
    Default New craz misfire codes
    Getting misfire codes on 1,5, and 6 cylinder. Some codes are even saying damaging misfire. I have listen to the motor and can feel it running just fine. No hiccups or anything. Was wondering if anyone else is getting these codes?
    2017 Moomba Craz
    Max Surf edition
    2018 Nissan Titan Pro 4X
    Feb 2016
    I would imagine, it would be difficult to feel a misfire on the water. Unless it's a dead hole.
    Sent from my SM-G935V using Tapatalk
    Jul 2016
    One thing that you could check is to make sure your spark plug wires aren't being crushed by the engine side panels when the rear water ballast bags are full. I installed some wake makers panel stiffeners on my engine side panels to help reduce the amount of flex. They would bend and hit the engine valve covers before I added the stiffeners. This is just idea of something to check. My boat never had a misfire problem.
    2016 Moomba Craz
    Jan 2017
    Alabama
    I am getting the code during these few hours I have put on the boat with out filling any ballast. I was wondering if the fuel I used could be causing it. I used 91oct with no ethanol. Dealer said he had a mondo do it the weekend before and that SC told him some motors were doing that during break in. I have payed close attention to the oil pressure and motor temp. Both were in the acceptable range.
    2017 Moomba Craz
    Max Surf edition
    Nov 2014
    Why would the fuel be causing it? Isn't the raptor minimum 89 octane?
    2016 Craz.
    Enzo bags.
    Jan 2017
    Alabama
    Quote Originally Posted by mattsask View Post
    Just looking at everything and anything that could cause it.
    2017 Moomba Craz
    Max Surf edition
    Jan 2017
    Mine threw a CEL and O2 sensor codes on Friday....first time taking it in the water. My dealer cleared the codes, put it in the tank and everything supposedly ran fine. I'm a little disconcerted at what is seemingly many new '17s throwing codes right out of the gate...these toys are too expensive for this kind of BS.
    2017 Moomba Craz Surf Edition
    Dec 2012
    Ennis, TX
    Quote Originally Posted by RC_Hinojosa View Post
    I have been told by the dealer that the Raptors do not like prolonged idle. It will throw o2 codes. Apparently they build up moisture at idol.
    Shane
    2016 Supra SE
    EXILED
    6 XM9 Tower
    6 Wetsounds XS650 Cabin
    1 EXILE BIG 12 DVC 2000 watt in a ported box
    1 XM 15.4
    XI 1500.1
    2 MX 30.2
    Wetsounds 420 EQ
    EXILE Blue tooth EXBT4
    Blue LEDs
    Quote Originally Posted by smorris7 View Post
    Feb 2017
    Wichita Falls
    I agree code on my 17 mojo too- high voltage
    FAE Dealer Message me for a Discount!
    2017 Moomba Mojo Surf Edition
    4600LB Ballast- Enzo Bags & Lead
    Fresh Air Exhaust
    4 Rev 10 Tower Speakers
