Results 1 to 2 of 2
03-30-2017, 05:16 PM #1Junior Member
- Oct 2015
- 13
Horrible Vibration in Steering Wheel
So...drifted a little close to shore (depth finder showed 3.5ft, which has never been an issue before) and upon restart and takeoff, I kicked up mud and possibly hit something. Boat ran fine, but we were cruising really slow, once we got moving, the wheel started vibrating horribly. I can turn the rudder, and the boat turns, as long as I'm under about 10mph, and above 10mph it quits shaking if i turn the steering wheel; I could drive full speed in a circle and no vibration. Small (1/2 inch) nick in prop and doesn't appear to have been bent, nor is the rudder.
Thoughts? 2005 Mobius LSV
As well, I bought a new ACME 1617 but my boatmate trailer doesn't look like it provides enough clearance, looks to need about half an inch...
03-30-2017, 05:54 PM #2
1/2 inch nick in prop is enough damage to cause considerable vibration.
Add spacers to your rear bunks on the trailer. Should give you the clearance for a larger prop.
Sent from my iPhone using TapatalkShane
2016 Supra SE
EXILED
6 XM9 Tower
6 Wetsounds XS650 Cabin
1 EXILE BIG 12 DVC 2000 watt in a ported box
1 XM 15.4
XI 1500.1
2 MX 30.2
Wetsounds 420 EQ
EXILE Blue tooth EXBT4
Blue LEDs
