Results 21 to 30 of 31
Thread: How many batteries do you run
04-08-2017, 07:01 PM #21
I ran 3 12v in the previous boat and never had a problem. I did not order the Mojo with dual batteries so adding 2 6v made sense for me. Unless you spend a ton of time with the boat off playing music, I don't think 3 12v's will let you down. 4 batteries will take up some space.
2016 Moomba Mojo
2006 Supra 24SSV - Traded
04-08-2017, 08:06 PM #22
Essentially a warm weather sport and a small block motor. I see no benefit in doubling up the two starting batteries. Either a) add one more identical 12V for a total of three, or b) remove one 12V and add the two 6V (recommended by many above).
There are schemes that have two identical banks, each consisting of two 12V deep cycles, so four total batteries. The idea is to alternate the role of the two banks each weekend, or normal interval, thereby limiting the number of deep cycles per each bank and extending the lifespan of the entire battery system. As mentioned above, any plan with four batteries consumes considerable space.
06-19-2018, 07:06 PM #23Junior Member
- May 2018
- 3
I need to replace my battery on my 2011 moomba and was looking at this add a battery kit. Is this a reasonable way to go?
06-19-2018, 08:28 PM #24
Depends on what you are after. The DCP switch and ACR is a great setup for its manual/passive operation. But, its hard to beat the simplicity of a basic 1/2/BOTH switch. For small to moderate sized house banks, the DCP/ACR setup works great. For all sized house banks, the basic switch works great, especially for larger house banks.
06-20-2018, 10:05 AM #25Junior Member
- May 2018
- 3
Thanks. It's a factory stereo and pumps, but we sit and use the stereo a lot so I think the DCP/ACR route would suit us best. How about battery recommendations?
06-20-2018, 10:24 AM #26
A standard group-24 marine cranking will be fine for the starter side. id go with a group-29 marine deep-cycle for the house side.
06-20-2018, 10:49 AM #27
I have 2 batteries
instagram
Mine -Crazy888smokey
The Moomba's -SauceySacs
Youtube -George Henry
2017 Moomba Helix
Just a guy & boat & girl & a couple of Fat Sac's & a ton of BEER ...trying to surf!!
06-20-2018, 04:16 PM #28
I run 2 batteries with a perko switch.
Sent from my iPhone using Tapatalk2016 Craz
2007 LSV - Sold
2003 Outback - Sold
06-20-2018, 08:41 PM #292021 Mojo, 6.2L Raptor 400/1.76, Acme 3407 15.5x13, G6, Flow3, +6500 lbs ballast
2005 Mobius LSV (sold)
Windermere Lake, B.C., 2800' Elevation
2021 Mojo Mods
06-20-2018, 11:23 PM #30
I’m just about to purchase this bad boy JUST to run my audio. All boat etc will be run from the starter battery.
Battery
http://www.enerdrive.com.au/product/...thium-battery/
DC to DC charter
http://www.enerdrive.com.au/product/...rger-40a-plus/
