Results 11 to 20 of 31
Thread: How many batteries do you run
03-31-2017, 06:20 PM #11Member
- Jul 2015
- 80
04-01-2017, 06:26 AM #12
04-01-2017, 06:46 AM #13Junior Member
- Apr 2017
- 1
04-01-2017, 07:36 AM #14Member
- Jul 2015
- 80
Run 2 D27 batteries parallel for your house bank and this will give you the run time you seek.
04-02-2017, 01:54 PM #15
I run 3 batteries. one is a "backup" so I don't get stranded. They are isolated with a perko switch. 2 of them for the "battery 1" setting and the other for the "battery 2" setting.
For simplicity, I have all 3 the same. I got the Walmart Everstart Maxx deep cycle group 29's. They are under $100ea and while I don't "need" a deep cycle for by backup/starting battery, it has enough CCA to start the boat just fine. Each of them is rated with a reserve capacity of 114 minutes.
Sure, I could be running AGM batteries and go with Optima or Oddessey, but for the money, I went with what will do the job and won't break the bank. Cost Effective!
If you don't want to switch out your battery box, you'd probably go with a group 27 instead. They were almost the same price.2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
04-02-2017, 03:44 PM #16
Has anyone thought about using two 6 volt batteries for the house bank?
2002 Supra Santera (SOLD)
2017 Moomba Mojo Pro Vivid Orange
(1595lb wakemakers in the lockers)
04-02-2017, 04:43 PM #17
I'd recommend the 2-6 volt battery if you have the space and handle the weight. I have a DD so I don't have a separate battery. I have used that configuration in my motor homes for the last 20 years and the golf cart batteries work best for accessories.
1998 Mobius
310 HP PCM
SOLD
04-02-2017, 04:51 PM #18
6v golf cart batteries can be a cost effective way to get a lot of Ah. They can take some abuse, but do require frequent maintenance.
04-02-2017, 05:10 PM #19
Another 6v user here. 2 6v for house and 1 12v for crank.
2016 Moomba Mojo
2006 Supra 24SSV - Traded
04-08-2017, 03:51 PM #20
