Results 1 to 3 of 3
Thread: trailer brakes
08-02-2006, 08:23 AM #1Member
- Jun 2005
- 51
trailer brakes
does anyone know a quick fix for the reverse lights on the boatmatetrailers with led lights. My circuit is not completing and I can not back up. without some crafty engineering on the surge brakes it is stuck. Dealer will make me miss a weekend to fix it. Although they knocked the light out when they had it for service how bout that.
08-02-2006, 08:57 AM #2Senior Member
- Mar 2006
- Chapin, SC
- 159
Replying to Topic 'trailer brakes'
if you have a four prong on your tow vehichle you can reverse the plug and only connect the three round prongs, leaving the square covered prong un attached. Do flip it first so that the square ends are 5 spaces apart. Then turn on your park lights in the car.... this is how I back.
I mess with Texas
08-03-2006, 05:16 AM #3Senior Member
- Jul 2003
- 340
If I'm reading it right, you already have the correct wiring and it just isn't working. If that't the case, get a test light and see if you have power to the reverse pin on your tow vehicle when you put it in reverse. If there's no power to the pin, it's your vehicle. If there is power it's your trailer. If it's the vehicle, just pull one of the tail lights out and hook a wire into the reverse light. Run the wiring down to your harness and replace the old reverse wire.
Trailer brakes locked
By SEARK in forum Service & RepairReplies: 3Last Post: 08-26-2007, 03:17 PM -
Trailer Brakes
By TN_Boarder in forum Service & RepairReplies: 10Last Post: 06-26-2007, 07:03 PM -
Trailer brakes
By kmcg in forum Service & RepairReplies: 5Last Post: 03-19-2007, 10:46 PM -
Trailer Brakes
By in forum Sales & InformationReplies: 0Last Post: 05-28-2003, 06:37 PM -
Trailer Brakes
By Catdog1 in forum Boat OwnersReplies: 2Last Post: 04-24-2003, 09:08 PM
