    May 2014
    Palm Desert, CA
    Default 2015 Mondo rear locker dimensions?
    So my my boat is 3hrs away and I'm trying to determine if it's worth it to upgrade my Sumo 900s with dimensions of 50x22x22 to the 1140 45x25x25 or the 1280 50x25x25.
    I also have a 250lb tube sack under port seat. Anyways just curious if any of this would be worth the upgrade? I emailed WakeMakers & here's their reply...
    Hey Brett,
    The 45x25x25 bags will give you more weight than your Sumo 900 but I am not sure they will fill completely. Your lockers are quite large but I do not have the exact dimensions.
    You can get the 1140lb bags or even the 1280lb bags and fill them with air to check the fitment but Once the bags are full of water we cannot take them back. Let me know if that helps or if I can answer any other questions.
    Thanks again!
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Hi, in December I upgraded to the 1140's from Wakemakers and they fit like a glove. I spoke to a fellow there and he was more than familiar with my 2015 Mondo and placed the order for me. Now I have two factory bags for sale!
    In addition, Wakemakers highly suggested I reinforce the side panels with aluminum channel, which I did. My previous factory bags did create a slight bulge.
    Hope this helps.
    May 2014
    Palm Desert, CA
    Quote Originally Posted by yukon2007 View Post
    Hope this helps.
    Thanks man, good to know. Yeah I already reinforced them when I did the 9s
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    May 2014
    Palm Desert, CA
    Or should I get this?
    https://www.wakemakers.com/straight-...llast-bag.html
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
