Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
    Dec 2016
    Illinois
    I was just asking because I considered the JL M12IB6 but was skeptical of the IB design.
    2016 Moomba Mojo
    Seems like it would be a big step down if you are considering 1000w subs.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Dec 2016
    Illinois
    That was my starting point
    2016 Moomba Mojo
    Quote Originally Posted by loc82 View Post
    Well you leaped up!! Double check me but I don't think your sub amp is ideal for the XXX. The JLw6 might line up better since it's dual 4 ohm?
    2016 Moomba Mojo
    Dec 2016
    Illinois
    does it seem like I'd be getting my money's worth with this set up at roughly 4k. Or should I go back to the drawing board?
    2016 Moomba Mojo
    Mar 2014
    Park City, Utah
    if you're questioning it, then you're probably not IMHO. 4k is good coin to drop on a stereo one would hope after the install you don't feel like you overpaid.
    2017 Centurion Ri237
    2013 Supra SA450 - Sold
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    don't use the Hu amp for anything in that setup.
    My initial instinct ....
    1. Not sure you will realize much benefit with the JL's in boat over the factory Kicker if you are not driving them with full power.
    2. I'm always gonna say you should strongly consider the Rev10 on the tower. It's such a dang good speaker.
    3. If you listen to rap and want thump, I'd zero in on the larger subwoofers and a ported box. JLw6, XXX, etc.
    On the sub, a JLw6 could probably work off the 5-6 channels of a 6 channel amp. The XXX is going to want more power.
    2016 Moomba Mojo
    Dec 2016
    Illinois
    Quote Originally Posted by sivs1 View Post
    luckily that's not the case. I haven't pulled the trigger yet or listened to the set up to be disappointed.
    2016 Moomba Mojo
    Dec 2016
    Illinois
    I will keep that in mind. The tech was throwing out different options on how to power the 6 speakers
    2016 Moomba Mojo
Tags for this Thread
