Results 1 to 10 of 21
Thread: Carb Adjustment
07-31-2006, 07:45 PM #1Member
- May 2006
- Pendleton, Oregon
- 48
Carb Adjustment
I have an 06' Outback with the 310 assault carbed engine. When I give it full throttle all at once it hessitates a little then takes off. I have read that this carb can be adjusted, can someone please explain to me how? When I took it in for my 20 hour service I told them about this problem and they said these carbs are set at the factory and can not be adjusted, other than the idle speed. Any info would be greatly appreciated.
07-31-2006, 11:42 PM #2Brian Raymond Guest
Replying to Topic 'Carb Adjustment'
Matt, your dealer is correct in not being able to adj. the idle air bleed screws. To help with your issue, make sure there is no clearance between the accelerator pump arm and the spring bolt, at w.o.t. with the engine off. You may want to see if the problem can be eliminated by, giving it 1/4 throttle and then to w.o. instead of a full dump. This gives the motor a sec. to build vac. Try this and keep us posted. Brian Raymond
08-01-2006, 04:31 PM #3Senior Member
- Mar 2006
- Chapin, SC
- 159
Matt:
If you do not live in California, then you can adjust the carb, you first have to remove the caps and have access to the bleed screws. Use a small drill bit and drill holes into the caps then pop them out with needle nose pliars, then close the screws all the way, open each up 1-1/4 to 1-1/2 turn and see how it is then...... This adjustment is usually for rpm at idle and puttering speeds, but if what Brian suggested does not work then I would try this. You may also have to adjust he idle screw. Do not get the rpm too high at idle as you will cause the transmission to engage too hard.
Im not sure if it is Indmar or SC that chose this CA emmissions thing, but it has to be the dumbest standard feature ever put on a boat. Let me guess: Al Gore has a 310 Carbed Moomba.
I had Idle problems and hesitation problems, performed this little surgery in 20 minutes and have not had carb trouble since. As I always state on this subject matter, since it comes up a lot, next year when mine is out of warranty I will get rid of the Holley 5150 P.O.S. and replace it with the proper marine grade 4 barrel Carb: Holley 4160. $500.00 at www.skidim.comI mess with Texas
08-01-2006, 07:55 PM #4Member
- May 2006
- Pendleton, Oregon
- 48
Thanks for all the help guys. My boat runs fine if I give it a little throttle before dumping it into full throttle. I may try turning the airscrews, but it doesnt seem necessary at this time. If I adjust the airscrews will this effect my warranty?
08-01-2006, 11:27 PM #5Brian Raymond Guest
Great to hear your up and running. The cap-offs on the idle air screws came about from a calif. gig. It will void your warr. if your carb should ever have to be replaced, and the caps are missing. I started thinking (I hate when I do that), that you can have up to .010 clearance on the acc. pump arm and the spring bolt with eng. off at w.o.t. Brian Raymond
08-02-2006, 08:40 AM #6Senior Member
- Mar 2006
- Chapin, SC
- 159
The email I got from Indmar on this specically states that my warranty will not be void as a result of removing the caps. I keep several copies in the event I should ever need it, as well, I ski with an ambulance chasing attorney. The manual states that the warranty may be void if you remove the caps; therefore, that was my insurance I obtained before I did it. If you decide you need to adjust them in the future I would contact Indmar and see if you could get them to authorize this.
If there was no need for these screws or no purpose then they would not be on the carb to begin with, instead there would be a permanet set point device thingy. So one has to ask how could the use of a standard feature affect warranty? Its nothing short of rediculous.
Anyone else ever adjusted these screws and had much better performance?I mess with Texas
08-02-2006, 01:02 PM #7Senior Member
- Jul 2003
- Carson City, NV
- 157
YellowMoomba,
I was having all kinds of engine problems at slow speeds and idle until I adjusted mine. Now you can barely tell the difference between this boat and an EFI engine. Runs great. I live at 4700 feet and often operate the boat at 6200 feet.
08-02-2006, 01:57 PM #8Senior Member
- Mar 2006
- Chapin, SC
- 159
Exactly my point. Running rough would probably do more damage than smooth, but then again Im no rocket mechanic.
I mess with Texas
08-02-2006, 04:26 PM #9Junior Member
- Feb 2006
- Scottsdale, AZ
- 28
Yellow,
Any chnace you could post a few pics for those of us who are less mechanically inclined? Where exactly are the "caps" and where should the holes be drilled to remove the cover?
My '06 LSV carb is a huge dissapointment. I knew I wanted the EFI when I bought the boat but I also had some real specific "needs" when it came to color scheme and options. Our dealer had the exact boat that I wanted except for the carb. I've never waited for anything so ordering a different boat never even occurred to me. Now, every time I sit on the ramp listening to my starter crank for about 3 min straight, I start thinking that maybe the color of the boat wasn't that important.
At any rate, after 4 separate services with the dealer, they are telling me that "the carb cannot be adjusted any more." I'd love to get in there and try the adjustment you're talking about. I also like the idea of upgrading the carb but my pregnant wife is already threatening to divorce me and my boat if I spend another dollar on it.
Thanks for the great info.'06 Mobius LSV.
08-02-2006, 05:04 PM #10Senior Member
- Mar 2006
- Chapin, SC
- 159
I have printed pictures somewhere, too bad this thing wont let me draw. I have changed jobs since I had the pictures on the computer and therefore do not have them. Lets assume then that the bow is north and the platform is south. Take the fire helmut looking cover off and looking at the east and west sides where the carb mounts about 1/3 of the way up from the top of the engine, at connection, on the "throat" (for lack of a better term) you will see 1 cap on each side closest to the north end of the boat. These caps look like leather furniture tacks. They are the same color etc. and are smaller than a dime in diameter but not much smaller. They are closer to the engine than the flame arrestor screen.
Be careful when drilling, use a small bit (i think i used smaller than 1/8 )and there is only the need to make a hole, take your time. You dont want to drill to deep and hit screws which may cause damage.
If I can locate the pictures I will get them scanned and posted, otherwise follow my little map and they should be obvious.
After you have access to the screws you will need a sunglass repair type flat head screw driver, which I think everyone has in there junk drawer. Finally, a use for this token of love from the aunt who drew your name at Christmas.I mess with Texas
Need Help With Windshield Adjustment....
By AaronWhitt82 in forum Service & RepairReplies: 6Last Post: 02-28-2008, 09:42 PM -
carb adjustment for altitude?
By iaonbb in forum General ChatReplies: 23Last Post: 09-01-2006, 04:19 PM -
Prop shaft packing adjustment?
By james yarosz in forum Service & RepairReplies: 5Last Post: 06-15-2005, 05:32 AM -
wakeplate adjustment
By Yellowmobius in forum General ChatReplies: 1Last Post: 05-11-2005, 12:23 PM
