Results 1 to 10 of 39
Thread: Pimp my Mojo stereo
03-01-2017, 12:59 PM #1
Pimp my Mojo stereo
I have a 2016 Mojo with the factory Kicker KX 200.2 amp, 4 Kicker in-cabin speakers and 4 Roswell 6.5" coaxial tower speakers. The tower speakers are running off the Kicker amp and the Fusion RA205 head unit is powering the in-cabin speakers. Thanks to this awesome forum and its members, I hooked up Dusty2221 and he is going to do the install for me. So far I have the following equipment purchased for the upgrade: Wetsounds HTX-6, Wetsounds HTX-4, JL 12W3-4ohm and Wetsounds 420 SQ. Dusty is going to build me a custom sub enclosure and install it under the drivers helm. The HTX-6 will power the JL 12W3 and the 4 Roswell tower speakers, the HTX-4 will power the 4 Kicker in-cabin speakers. I am hoping that once the in-cabin speakers and towers are properly powered and everything is dialed in/EQ'd that this will bring them to life. I have also purchased LED cup holder rings from Blast LED that he is going to install/tap into my courtesy switch. Once everything is done, I will send pictures of the install and follow up on the outcome.
Is it boat season yet????2018 Supra SL550 with 850lbs of lead wake
2017 Supra SA400 (Sold)
2021 GMC Denali 2500
Soulcraft Vodoo
Soulcraft Jordi Pro
Soulcraft Super AV
Phase Five Matrix
03-01-2017, 01:11 PM #2
You won't be disappointed.
I bet it really brings the current speakers to life. I'm anxious to hear ya'lls thoughts when it's finished up.
PS: I've seen your box and it looks greatLast edited by KG's Supra24; 03-01-2017 at 01:13 PM.
2016 Moomba Mojo
2006 Supra 24SSV - Traded
03-01-2017, 01:16 PM #3
I'm sure you won't be the only one to see my box...
Soulcraft Vodoo
Soulcraft Jordi Pro
Soulcraft Super AV
Phase Five Matrix
03-01-2017, 01:37 PM #4
Id consider using the HTX-6 for the two pair of in-boats and woofer. Same wattage as the scenario above, but this gets the two hardest driven zones on different amps. This also still allows for a 3rd pair of in-boats to be added.
2nd, why not an HTX-2 for the 2 pair of tower speakers? More wattage, less $$$ then an HTX-4.
Just a couple suggestions to ponder.
03-01-2017, 02:10 PM #5
Where's the like button?
Sent from my iPhone using Tapatalk2015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
03-01-2017, 02:45 PM #6
MLA is right, the HTX 6 Should power the inboats. Originally the HTX6 was going to be the only addon, so it made sense for the towers to go on it. With the addition of the HTX4, the cabins will share the HTX 6 with the sub and the towers will to the HTX 4.
As far as the HTX4 vs the HTX2, it is future proofing for an upgrade to a pair of larger tower speakers down the road. So for now, the HTX4 will be giving each 6.5" coax on the tower 100w (compared to the 50 each currently). In the future, with the HTX4 already installed, he can upgrade to a pair of larger hlcd towers and already be amped for it with 300x2, vs the HTX2 needing to be replaced.2006 Supra 20 - Sold
2015 Supra SE450 - Sold
03-01-2017, 03:06 PM #7it is future proofing for an upgrade to a pair of larger tower speakers down the road
03-01-2017, 04:29 PM #8
And that is why Dusty gets paid the big bucks!!!
Soulcraft Vodoo
Soulcraft Jordi Pro
Soulcraft Super AV
Phase Five Matrix
03-01-2017, 04:36 PM #9
That's a solid example of how saving $20 this year cost you $400+ the following season.
If you want people to see the box you better get a pic! Once he puts the facade on, it will look like it came from the factory.2016 Moomba Mojo
03-01-2017, 05:26 PM #10
Pretty sad, that I don't even have pictures of my own box
Soulcraft Vodoo
Soulcraft Jordi Pro
Soulcraft Super AV
Phase Five Matrix
