Results 1 to 6 of 6
02-23-2017, 04:16 PM #1Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
2016 Mojo / Fusion Head Unit Wiring Diagram
So, admittedly - total laziness on my part for not detailed searching of the web, but quick attempts at the forum or Google were not successful. Does anyone have wiring diagrams on factory setups from 2016? I'm about to get deep into mods and my setup is the fusion head unit, 4 main cabin speakers and 4 Roswell tower speakers. I have the factory KX200 amp.
I'll be installing new tower speakers, 2 new amps, a sub, and 2 bow speakers.
Thanks in advance for any help.2016 Mojo Surf
Raptor 400
FAE
02-23-2017, 04:18 PM #2
Adding an EQ or zone control as well?
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
02-23-2017, 04:32 PM #3
Dusty will have better details but all the speaker wires will be where the factory amp rack is. The battery is located near the amp rack so it's fairly straight forward. You will likely need to run new RCA's from helm to amp rack compartment, though.
Depending on what amps you go with, it's possible to reuse the factory amp rack. I needed a bit larger board so Dusty actually pulled the facade from the helm and used it as my amp rack, screwed back onto the factory amp rack braces.
More than likely, your bow speaker wires are already ran.2016 Moomba Mojo
2006 Supra 24SSV - Traded
02-23-2017, 04:33 PM #4Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
The fusion unit has 2 zone control and also got the Exile EXZD (if that is the right acronym) -- the line dual volume, not the EQ.
2016 Mojo Surf
Raptor 400
FAE
02-23-2017, 06:15 PM #5
I use a 420 for volume in different zones but the Fusion unit can handle it in a fairly simple manner. I believe you can push the volume to cycle through the zones. How you run the RCA's will determine the zones.
I don't know anything about the EXZD. It may be even easier than using the fusion.2016 Moomba Mojo
02-23-2017, 07:25 PM #6
The 205 actually has only one set of pre-out RCA and they are tied to the front speakers. The zone in the 205 is really no more than front rear fade.
